Need help decoding 8 inch Ford rear end tag
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Jan 19, 2010.
  1. Roothawg
    Roothawg
    I have an 8 inch out of a mid 60ish Ford. I used to have a page bookmarked but all the info is gone. I guess they took down that page.
    Tag number WCL-H2
    3.00 3KE 801
    I know what ratio it is, but I need a year so I can get axle bearings, pinion seals etc.
    Thanks
  2. Roothawg
    Roothawg
    Anyone? Bueller?
  3. all 8" ford rears have small wheel bearings
    wheel bearing rw207ccra
    axle seal 13700
    pinion seal 18100
  4. 333 Half Evil
    333 Half Evil
    I just wanted to add this, do not always go by the tag. I've had it before where someone prior to me working on a certain axle they must have swapped center sections or something and the tag info was wrong. I always suggest pulling the axles and getting the numbers from the bearings or at the very least a measurment. Same goes with the seals.
  5. Roothawg
    Roothawg
    Thanks guys. Exactly what I was needing.
  6. Deuce Roadster
    Deuce Roadster
    To add to this ...
    A lot of rodders will find the RATIO rear end they want in a junk yard and not have the time or the $$$ to get that day. They then switch the tags ... SOOOO ... no one else wants it. :D
    Then life gets in the way and the rear end lays there until you come along. If the rear end tag and the door info tag for the rear end ratio match ... then you are fairly safe figuring the rear end is as it came from the factory
  7. FLAT-TOP BOB
    FLAT-TOP BOB
    HAMB O'dex Editor
    wcl-h = 64-65 ford fairlane
  8. moefuzz
    moefuzz
  9. Roothawg
    Roothawg
    I guess I need to count the teeth to be sure, but it looks like it has never been apart. It's nothing fancy, so I doubt anyone would go to that much trouble for a dog leg rearend.
  10. train
    train
    Ñeed help with rear tag I know its a ford 9in. WEY.AA1 7ED
    oo75. 9. 718A what year and what gear ratio it has two dots then 75. Told it was 275 gear ratio thanks
  11. train
    train
  12. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Are your axle tapered or is the tube straight across .
  13. squirrel
    If it's a 2.75 ratio, and not a Track Lock, it will say 2.75. But the 2 might have gotten messed up so there's only a dot left....
    Dont see that code listed here.
    http://www.fordification.com/tech/rearends_ford06.htm
  14. Roothawg
    Roothawg
    I have another one I can't seem to find on the net.
    C2SA 4001 J 403 11D
    Ratio 3.00
    The housing is roughly 56.5" wide
    Round housing, 2 dimples, fill plug
    It has 11" drums with 2.5" wide shoes.
  15. Roothawg
    Roothawg
    Anyone have a Hollander or something similar?
  16. NMCarNut
    NMCarNut
    What info are you seeking from a Hollander?
  17. Roothawg
    Roothawg
    Trying to figure out what backing plates/brakes will interchange with the 57-59 ford axle. I think??? Axle I have for parts is a 60-64 Galaxie. I haven't had time to tear it all apart to see if the bearings are the same size. I'm out of town for a couple weeks but I took a few measurements.
  18. NMCarNut
    NMCarNut
    Unfortunately Hollander does not go down as far as backing plates. You also need to be aware of axle offset which is 2-3/8". While I have not tried, been led to believe up to 66 Ford backing plates/brakes will work, so you should be good to go.
  19. Roothawg
    Roothawg
