Need help drilling...
Discussion in 'The Hokey Ass Message Board' started by LOST ANGEL, Jun 7, 2006.
  1. LOST ANGEL
    LOST ANGEL
    a hole through carpet without unravelling the whole damn thing. What are your secrets, need to drill holes to mount my seat belts. Thanx-MIKE:)
  2. Rivet
    Rivet
    Put the drill on counter clock wise and put some moderate force and it will work like a charm.
  3. Powerband
    Powerband
    Me thinks you'll just as well unravel in reverse as well...
    Only way I know is to cut with utility knife before starting.
    I install wires for a living and seeing a 10' string of new carpet disappear from the floor as it wraps around the bit is not good.
    Powerband :cool:
  4. 56don
    56don
    I use a hot soldering iron to melt the hole through.Leaves a sealed edge.
  5. Belchfire8
    Belchfire8
    Used to use a length of cut off coat hanger to drill holes through house carpeting to locate floor register locations.....probably won't work on a steel car floor...just an X with a utility knife, drill in the center....
  6. Flatman
    Flatman
    A 3/8" hole punch from Tandy Leather would make a nice clean hole.
    Flatman
  7. 23 bucket-t
    23 bucket-t
    also use duct~tape ...... put a piece of duct~tape where you want to drill X with the knife, drill. :D
  8. I was thinking the same thing.Back the metal up with a piece of wood & punch the rug.
    I really like the soldering iron idea too.
  9. Ragtop
    Ragtop
    I grind all the teeth off an old hole saw, leaving a sharp edge, Works for me
  10. 23 bucket-t
    23 bucket-t
    let us know what worked...... :rolleyes:
  11. ntxcustoms
    ntxcustoms
    from dfw
    Now that is a great idea! So damn simple...
  12. Bear Metal Kustoms
    Bear Metal Kustoms
    Alliance Vendor
    Stepped drill bits work for me...Twist bits grab the carpet... Stepped bits didn't seem too bad....EVILT
  13. 48fordnut
    48fordnut
    Learned the soldering iron trick watching a guy work on his car. i use it any time i need a hole in carpet.
  14. Slag Kustom
    Slag Kustom
    i use leather / gasget punches with a peice of 1/2 plywood under it. gives a nice clean hole. soldering iron works great but the smell ****s.
  15. Yeah it stinks when melted but theres always a chance of a fire,or someone getting blistered.(dont we all like the danger factor?)Soldering irons will get ya if youre not careful,but a very useful tool.
  16. old yeller
    old yeller
    from hebron, ky
    You can cut the carpet with utility knife, and then use a short piece of s**** tubing inserted into the slit to drill thru.
  17. junkmonger
    junkmonger
    Yup, a solder iron is what I use too. It's simple and gets the job done.
  18. fab32
    fab32
    I've also done the rug unraveling deal and here's what i've learned that works. Find the hole location and use a very thin punch and pierce the carpet and the floor. Then take a long tapered punch and continue to open up the hole to the desired dia. After you get the hole to size go under the floor with a disc grinder and remove the flared metal that was punched out of the way. Be careful to pull the carpet up while doing the grinding as it will smolter from the grinding. You now have the correct size hole and an unmolested carpet.
    Frank
  19. LOST ANGEL
    LOST ANGEL
    Cool.. thanx gents. I think I'll try the soldering iron idea first, got a new fire extinguisher anyway!-MIKE:eek: :D
