does anyone know the size of the rear end that came in a 1952 mercury sport coupe? was it 7 inch? theres no tag on the rear end and i need a drive shaft/ rear end coupler yoke ASAP
Far as I know, 52 to 54 merc only had 1 rear end. May be the same as 49 to 55 Ford. I don't remember rear ends catagorized by ring gear size back in those days.
If the center section drops out the front, it's same as Ford '49 thru '56. If it has a removable rear tin cover on the center section, it's ****er axle, likely a model 41. In either case, there is only one u-joint for either of them and it may very well be the same for both. MAC's, Rock Auto or Kanter's, to name a few, can supply a u-joint. Not sure if you need a u-joint or driveshaft yoke from your phrasing. Ray
What Ray said is right on the money, and from experience with those cars I'll add that you can find parts for those, but unless you're lucky they won't be in stock at your local chain parts store
