need help finding bolts!!!
Discussion in 'The Hokey Ass Message Board' started by FORDOLE500, Apr 20, 2006.
  1. FORDOLE500
    FORDOLE500
    I am looking for a bolt that is approx. 1/2" or 3/8" long x 1/4-20 thread but the head looks like a rivit. I want to know what they are called and where to buy them
  2. 53sled
    53sled
    from KCMO
    Lag or deck or bumper bolts? with a square shoulder under the cap, right?
  3. KustomSkylark
    KustomSkylark
    from Sacramento
    Arn't those called anchor bolts or something, go to your local ACE they have those things.
  4. KustomSkylark
    KustomSkylark
    from Sacramento
    I mean carriage bolt, thats what i think they are called.
  5. Any Home Depot or Lowes will have them....
  6. FORDOLE500
    FORDOLE500
    no, no square shoulder they are not carrage bolts , i have herd them called huck bolts. that bare metal rpu called the a-bomber has them all over it
  7. ProEnfo
    ProEnfo
    from Motown
    http://www.mcmaster.com/
    ..just type huck bolt in the find box..
    CC
  8. Unkl Ian
    Unkl Ian
    Rogue did a bare metal rpu a couple years ago,using bolts like you describe.
    He called them "locker bolts",used to bolt storage lockers together.
    Unfortunately,his supply got depleted,and the source dried up.
  9. 19Fordy
    19Fordy
    http://www.portlandbolt.com/products/buttonhead.html
    Those are called Button Head Bolts. Click on the above link.
  10. Gerry Moe
    Gerry Moe
    it sounds as tho you are looking for a security fastner either a hex or square hole with a small dowel type in center. You live in CA so check for a fastenal fastener wharehouse as said before www.mcmaster.com is good
  11. ray
    ray
    from colorado
    i'll second the "locker bolt" name, don't know if that official though.
    the ones he is looking for are not button head or security bolts, they have nothing on the head but a smooth dome, and are serrated under the head to grip the piece you are bolting to keep from turning.
  12. Unkl Ian
    Unkl Ian
    Did you check the length on those ?
    Definately too long for the original question.
  13. :confused: Huck bolts are made to attach sheet metal to sheet metal, buy the length you need................
  14. rocknrods
    rocknrods
    Sounds to me like your basic 12-2 Alpha, Delta Charlie!
  15. Vergil
    Vergil
    Button Head Cap Screws
  16. Good luck. 10/32 locker bolts.....................................
  17. Unkl Ian
    Unkl Ian
  18. Unkl Ian
    Unkl Ian
  19. PatJ
    PatJ
    from Dallas
