need help firing an engine
Discussion in 'The Hokey Ass Message Board' started by ramrod2624, Jul 26, 2009.
  1. ramrod2624
    ramrod2624
    I am at a point where I want to fire the engine sitting in the frame Of my 41.
    its a 283 chevy bare frame no wiring other then What I have set up to fire the motor.
    Heres where im at.
    I have a cable hooked to a battery from the B post on the starter.
    I have a ground from the Battery to the frame.
    I have a wire from R Starter to the Positive on the coil.
    I have the Black wire from the distributor to the neg on the coil.
    I have relocated the red wire (Pertronics ignitor installed in distributor) to the battery
    I have a remote starter button hooked up
    Battery and the S off the starter.
    The Engine has fuel to carb
    It sounds like it wantes to fire but one I let up on the button off the remote it dies.
    What am I missing to keep the engine running?
    Im trying to get this fired today so any help would be great!
  2. flamedabone
    flamedabone
    You need a wire to power the coil when the engine is running, not just when cranking. Run a wire from the battery to the positive on the coil, and lose the one from the R on the starter, it will no longer be nessessary.
    Good luck, -Abone.
  3. budd
    budd
    i would put a toggle switch on the wire going to your coil so you can shut it off easily.
  4. that's it........make sure you can take the wire off easy (like an alligator clip) because that's going to be the only way to shut the motor off.
  5. ramrod2624
    ramrod2624
    A bone / oldtimer,
    Thanks that did it!
    Now I have an electric oil presure gauge on this , when the motor ran no oil pressure. I have the wire from the sender to the gauge and then from the gauge to ground.
    The motor is not grounded would that make a difference?
  6. squirrel
    sender needs to be grounded, gage needs to be grounded.
    I always screw a mechanical gage into a fresh engine, and check the pressure when I pre lube it, and watch the gage when it starts up too.
  7. I think the electric gauge needs 12 volts to it. And ditto on what Squirrel said.
  8. ramrod2624
    ramrod2624
    Thanks ill put a mech gauge on it. When I prelubed it/ primed the oil pump I wathced it flow out the top part of the distributor housing.
    Can I just screw a pressure gauge in to the port im picking up presure from? say like a 0- 60 psi gauge?
  9. squirrel
