Technical Need help from OZ.
Discussion in 'The Hokey Ass Message Board' started by CA. 280, Jun 14, 2015.
  1. CA. 280
    CA. 280
    Could someone verify a couple of dimensions for me on the T-5 from a Holden Commodore. Info I have says the distance from the front of the case to the centerline of the shifter is 23.4" and the input shaft protrudes from the case 9.5" Thanks in advance.
  2. flatoz
    flatoz
    Can't help you with the measurements, but are you after a 6cyl version or V8 version measurements? They may be different? I do know that they use the Ford bolt pattern
  3. swifty
    swifty
    I've got a Falcon version in the shed. I'll measure that and post my findings.
  4. All T5's, V8's and 6's used here in Oz use the Ford gearbox/bellhousing bolt pattern, the only exceptions apparently were some early/mid 90's Commodore V8 SS's or some such animal that used the Chev pattern gearbox........all T5's here use the rear shifter also..........this is what I was advised by a couple gearbox experts a few yrs ago when I imported my S10 T5.........for various stupid reasons I sold it so can't go measure anything........Mal Wood who advertise in Aust Street rodding are a good source for info, parts etc.........andyd
  5. 2 I have measure 21 1/2" ,shifter centre line to mounting face and they have a input shaft length of 6 1/2" from the end of shaft to the mounting face.Both of these are Ford
    The third one is 22 1/2" and 9 1/2" on the same measuring points.This one could be Holden.
    Hope this helps.
  6. CA. 280
    CA. 280
    Thanks everyone, any links to where I could buy a Holden input shaft who would be willing to ship to California would be appreciated.
  7. CA. 280
    CA. 280
    Should add, does the Holden have a 1352---- # on it?? thanks again.
  8. Ratrod_Rhysie
    Ratrod_Rhysie
    does anyone no if a falcon t5, say ef falcon early xh or xg falcon ute, are same as pre 93 mustang t5??
