Hot Rods Need help from Tig Welding guru's
Discussion in 'The Hokey Ass Message Board' started by jailhousebob, Sep 6, 2017.
  1. jailhousebob
    jailhousebob
    from Illinois
    So i've been Tig welding for a number of years now and i do ok with it technique wise.I grew up gas welding so the transition was not difficult. The problem i have is being able to see the work.Even at the lightest setting on my helmet( #9) i struggle to see the puddle. Now i'm welding sheet metal and using a 1/16th tungsten at about 32 amps and the arc isn't bright enough to see anything. I tried putting a floodlight on the work but that seemed to make the shade get darker. My helmet is a Miller and is about 15 years old.It seems to work properly . Am i doing something wrong ,need a new helmet or just going blind. Thanks,Bob
  2. saltflats
    saltflats
    from Missouri
    Maybe a magnifying lens will help.
    seb fontana likes this.
  3. Chavezk21
    Chavezk21
    I am just learning to tig. The fellow teaching me runs the bead towards him and uses 1 amp per thousansth of an inch. so for 18 gauge that runs at about .042 or 42. seems to help me as I was having the same problem.
  4. jailhousebob
    jailhousebob
    from Illinois
    I actually wear magnifiers to read and for close up work so i am wearing them to weld.The problem is brightness,or lack of it.It is just too dark for me to see anything. I barely see the puddle and constantly wander from the seam because i can't see it.
  5. Blue One
    Blue One
    from Alberta
    Do you wear gl***es during non welding activities ? If not then you are probably going to find very soon that you need them for reading and maybe even other things, quite often as you get older you discover that you can't see quite as good as you think you can.
    If you wear gl***es now just for reading, then you will definitely need them for Tig welding.
    Tig welding is very dependant on vision acuity meaning that you can't weld what you can't see.
    You need very sharp close up focus vision that is one of the first things you lose as you age.
    If you wear gl***es that are bi focal or multi focal, you will quickly find that for welding they won't work, in fact they **** making it more difficult because you are constantly shifting your head around trying to find the sweet spot where you can see clearly.
    As mentioned reading gl***es can help as can welding magnifier lenses commonly called cheaters.
    Better yet is a dedicated pair of gl***es from your optometrist for close up work like welding or reading.
    The reason ? Because quite often one eye will need a stronger magnification than the other eye, both lenses will not be the same like what you buy in the drug store.
    On top of that you can get proper safety lenses which drug store reading gl***es are not.
    Another way to go, which I have now is something called mono vision.
    Your optometrist will fit you with a lens for one eye that will give you medium to distance vision and the other eye will have the close up focus reading and welding prescription.
    He can tailor the strength of the lenses so that they work together for both close up and distance vision.
    It's really quite amazing and I have safety gl***es that work both for welding and in other duties around the shop which is important throughout the day working with the students, without the problems ***ociated with my regular progressive bi focals which are my street gl***es.
    Hope this info helps you out, I learned all this during my career as a pressure Tig- stick pipe and vessel welder and then instructor starting when I was a sharp eyed youngster at 18 till now at 63.
    Larry
    Fitty Toomuch, crminal and loudbang like this.
  6. Budget36
    Budget36
    I tell ya, I had to actually darken up my old Huntsman insert, after I pulled the cover plastic off and replaced it, and cleaned the unit, and changed the inside cover as well..
    Eff, the things I can see now;)
  7. jailhousebob
    jailhousebob
    from Illinois
    Already changed the plastic covers and made sure everything is clean.
  8. Blue One
    Blue One
    from Alberta
    By the way, including the info supplied above I also use a #9 shade setting on my helmet ( Miller Digital Elite) for welding all processes.
  9. Budget36
    Budget36
    Ya, then do as above, I don't have a cheater lens, but I have a pair 1.75 mag reading gl***es I use when welding, without them, I couldn't follow a thing...dollar store for a buck!
  10. Sheep Dip
    Sheep Dip
    from Central Ca
    In the old style hood with the roughly 2 X 4 lens I used a "Cheater" magnifier, with the new bigger window auto dark type hood I just wear drugstore gl***es.
    My problem is I can't get my head back anymore so I'm pretty much stuck with what I can weld on the bench or I can easily see.
  11. gimpyshotrods
    gimpyshotrods
    I use a magnifier in every welding helmet. Combined with my transition lenses, it seems to do the trick.
  12. Like you, I graduated to TIG welding from doing oxy/acetylene welding. Also, like yourself, I find that my short vision is going to hell in a handbasket, and the light has to be perfect to do a real good job. I am 74, and find that even though my near sight isn't the best, I still work better without gl***es than with cheaters.
    My helmet is about the same age as yours and it still works great, but I find that the batteries have to be fresh for the helmet to work at peak efficiency. I did notice that having any ambient light behind the welding helmet makes it more difficult for me to see the work before I strike the arc.
    I don't know if it will be helpful, but I have found that watching the TIG welding demonstrations on youtube have been really helpful for me. I have a Miller TIG, and have no excuse for not using it more often. Just for convenience, I often grab the oxy/acetylene torch just because it is so convenient, and I should be using the TIG for some of these jobs.
    Bob.
  13. Budget36
    Budget36
  14. Blue One
    Blue One
    from Alberta
    Lenses that go darker in the sun and lighten to clear indoors.
    I have them.
    They're great for outside but won't help when driving or welding.
    Beyond seeing better of course.
  15. Budget36
    Budget36
    ***ume they would go on the inside of the helmet, ...i/e in front of the welding lens?
  16. gimpyshotrods
    gimpyshotrods
    They are eyegl*** lenses, and yes, they do react to light when welding.
    Budget36 likes this.
  17. Budget36
    Budget36
    Thanks, gonna have to look into them :)
  18. southcross2631
    southcross2631
    I wear gl***es all the time. Except for welding, can't get the right focal length with them on. I have mounted a small light from harbor freight . Took the straps off and velcroed it to my helmet. The light focuses on where I am looking. It seems to help a lot.
    Like you I could make a beautiful right beside where I was trying to be.
  19. vtwhead
    vtwhead
    someone on here had a thread about velcroing a led head lamp to his helmet and stated that it was the fix for his predicament of not being able to see the puddle fwiw
  20. oj
    oj
    I use #8 shade, for sheetmetal I'd try #7 if I could find it. I've even tried adding LED lights to my helmet with marginal luck. The biggest help came from magnifying lens and I'll even wear 'cheater' goggles inside to double the effect. I don't need gl***es to read or anything but the magnifyers make a difference.
    I think part of it with magnifyers you have to get your head closer to the work, I'll be right on top of the puddle.
    The other thing is technique, you have to have ultra clean & sharp tip, a little goo on it or erosion rounded tip will loose focus on the arc and that makes a big different in being able to see whats going on.
  21. Blue One
    Blue One
    from Alberta
    Their reaction to light while welding is very minor, they will not darken fully like they will while you are out in direct outdoor sunlight or outdoors in general.
    The same as when you are in a closed vehicle, they don't darken fully then either which results in them not working well as sungl***es for driving.
    And yes, they are eye gl*** lenses and are not available as welding lenses for your helmet.
  22. papadaddio
    papadaddio
    from Minnesota
    Try a different helmet
  23. Burkedore
    Burkedore
    Get a fixed shade lense and spring for a gold coated one. They let you see more true color instead of just shades of green. It can be especially helpful with Tig because when you contaminate the tungsten the arc changes color.
  24. Joliet Jake
    Joliet Jake
    from Jax, FL
    I have a 9100 series Speedglas hood that starts at a #5 which is more of a cutting/gas welding shade, then #8 on up. I have never had an issue seeing the puddle, as others have said it may come down to trying a different hood.
  25. carryallman
    carryallman
    i have had a "speedgl*** " helmet for yrs -they are the cats meow!! my last one went bad -bought a miller "elite " w/ cheaters - its nice BUT the headband is junk -it wont stay adjusted - no matter how its adjusted !! them "speed gl***es" with the "3 m" head band WORK GREAT _GREAT - the speed gl*** was about 60.00 more -i got cheap ! the miller had a good line of sight - but when i get a little more money -i will buy another "speed gl*** " 11111111111111
  26. Happydaze
    Happydaze
    When tig welding I have my face about 6, maybe 8 inches away from the puddle. I use stronger drug store reading specs than I use for reading. Before I realised my need for reading gl***es I found my welding had deteriorated m***ively! I didn't realise I was just guessing where the action was.
    I can't tig weld at arms length to save my life. Kinda difficult sometimes if there's stuff in the way.
    Chris
  27. gimpyshotrods
    gimpyshotrods
    Perhaps you have a different brand or generation.
    This is what I have: http://www.transitions.com/en-us/products/transitions-xtractive/
    They go full-dark, inside the helmet, with the auto-dark shade set to anything #9, or lower, every time.
  28. I use a 2x diopter and my prescription readers. When I shadow the arc, I can still wander off my line. I find aluminium extremely difficult to see the puddle. I go from no puddle to slight sheen, to hole, repeat. Frustrating
  29. Blue One
    Blue One
    from Alberta
    Mine are the regular ones for which what I said is true.
    The extra active ones would be nice at times.
  30. I agree after 45 years or so of doing my damndest to burn my eyes out of their sockets I have discovered that I cannot see the puddle without my gl***es on.
    Welding, and computers are extremely hard on your eyes, compound that with the solvents that we used to use to clean things ( many cause cataracts) and you just need a little help.
