need help front spring
Discussion in 'The Hokey Ass Message Board' started by ICEMAN-29, Jan 8, 2012.
  1. ICEMAN-29
    ICEMAN-29
    from colo.
    I would like to know if anyone has cut down a front leaf spring I want to shorten the main spring by cutting it down and rebending the bolt holes but i,m afraid I will make the ends brittle or I will or take the spring out of it any Help would be great Thanks iceman-29
  2. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Reroll the eyes ,Dont rearch
  3. Andy
    Andy
    You need special equipment to rework a spring. I just had a new main leaf made. I carefully drew a full size plan of what I wanted and took it to a spring shop. It took a couple of hours and cost $60. I put in yesterday and it is perfect.
  4. F&J
    F&J
    re-rolling the eyes correctly, is close to impossible by most of us. The end of the piece needs to be tapered and then rolled precisely to hold the bushing properly.
  5. carcrazyjohn
    carcrazyjohn
    from trevose pa
    I disagree ,Cut off wheel will get you the taper and sockets will give you the diameter.My spring rerolled came out better than my dads fom a spring shop.His words not mine
  6. Fordtudor37
    Fordtudor37
    The guy I go to is Posie's.
    They do good work and warranty it.
  7. John;
    now tell us the rest.
    did you heat to white or red?
    Did you re-temper?
    How about tech article?
    Thanks,
    Bill.
  8. rusty rocket
    rusty rocket
    Ive always taken my springs to a spring shop and have had great results everytime.
  9. NJRATRODER
    NJRATRODER
    from NJ
    If you pm me what you need. Iwill see if i can help you out. I work at a spring shop.
