Need help getting nut off of generator fan and pulley
Discussion in 'The Hokey Ass Message Board' started by HomemadeHardtop57, Aug 11, 2010.
  1. HomemadeHardtop57
    HomemadeHardtop57
    Here's a stupid question. I want to take the pulley and fan off the front of my generator so I can paint it. Im afraid that if I wedge something in the fan to prevent it from turning while breaking the nut loose I might hog the fan up. Is there an easy way to do this that I'm not thinking of...thanks for the help
  2. redlinetoys
    redlinetoys
    from Midwest
    You need a powerful air ratchet. The hammering action will get the nut loose before the fan spins, or quicker then the fan can spin. Give it a try.
    Some people will hold the fan with a rag or towel wrapped around it. Be careful.
  3. kdorfner
    kdorfner
    Yeah, I use an impact gun and the nut just spins right off.
  4. HomemadeHardtop57
    HomemadeHardtop57
    I tried using an air impact but with no luck it spun the fan...I'm going to give it another shot tomorrow.
  5. stuart in mn
    stuart in mn
    Is the generator off the car? Wrap the fan belt around the pulley, and clamp the belt in the vise to hold it in place.
  6. Dr.Slam_Jessies_Customs
    from Las Vegas
    spray the nut with some penetrating oil then give it another shot. if not try a different impact for some reason out of the 3 that i have only one likes to take the nuts off alternators
  7. Retrorod
    Retrorod
    Put five drops of air-motor oil into your air fitting on your 1/2 drive impact...wrap a rag around the fan and then slam it...it'll come off.
  8. cornbinder52
    cornbinder52
    I have a corded 1/2 impact from Kobalt. Have not found much it can't crank off.
  9. HomemadeHardtop57
    HomemadeHardtop57
    thanks for the suggestions. I'm going to give it hell tomorrow...I'll get it off one way or another.
  10. JoeySwass
    JoeySwass
    If you have access to a replacment nut, you can just break the nut off with a nut splitter (if the impact wont do it)
  11. FC49
    FC49
    My air impact hasn't been used since I bought the electric.
  12. cornbinder52
    cornbinder52
    We use the electric to drive concrete anchor bolts. They look like lag bolts that are not tapered. It drives it with ease, and it does not give me fits like my air impact does.
  13. Bruce Lancaster
    Bruce Lancaster
    Another way...strap wrench. It might grip pulley adequately, will certainly grip armature.
    I have a new Klein one found at Sears that has an almost sticky surface on the belt, which really helps get it engaged.
  14. low-n-slo54
    low-n-slo54
    I hope you get your nut off.
  15. fms427
    fms427
    I use a ViceGrip on one of the fan fins and an impact wrench (air). Always works the first time....
  16. HomemadeHardtop57
    HomemadeHardtop57
    got it off today with another impact..came off easy
