need help hunting a shorting noise on sbc WITH video.
Discussion in 'The Hokey Ass Message Board' started by Tim, Aug 13, 2013.
  1. Tim
    Tim
    from KCMO
    Fixed it, had the rubber washer for the ****on under the coil in the wrong place.
    I had it in position A it's evidently supposed to go in position B
    By the way I brought the cold beer but don't think I ever saw you Abone
    Posted using My **** Tracy watch and the full custom HAMB app
  2. 54Buick48D
    54Buick48D
    from Maryland
  3. Atwater Mike
    Atwater Mike
    Then how do ya get your car outa the garage? Push it?
    Had to ask...
  4. Tim
    Tim
    from KCMO
    man with a new coil, cap, rotor, plug wires He's running like a whole different car haha
  5. Jay Tyrrell
    Jay Tyrrell
    Did you put in a ground stap I the end? You should mail him that beer man!
    Jay
  6. Tim
    Tim
    from KCMO
    actually truth be told I pulled it apart and changed that little washer thing and it fixed everything, I then moved a box on the work bench and the ground strap fell out of it! so for ****s and giggles I took it all back apart even though the noise was gone and put the ground strap in to make the HAMB happy ;)
  7. Gregg Pellicer
    Gregg Pellicer
    Be glad you put that ground back on. If left off it would have taken out the module.
    Gregg
  8. Speaking of that dreaded module, you (and anyone else running a HEI) should have one in the glovebox and a cheapy nut driver set to change it. They give NO warning when their going to go! Can turn a disaster into a 10 min. delay....
  9. S_Mazza
    S_Mazza
    I find it works better to back out with the door open. Otherwise, it wakes up the neighbors. ;)
  10. willys1
    willys1
    from South Ga
    Good job Tim! Glad its fixed :)
