need help id this transmission mount
Discussion in 'The Hokey Ass Message Board' started by anton, Feb 22, 2006.
  1. anton
    anton
    I want to renew this rubber mount, but I don't where came of.
    I have a 1939 Lasalle transmission.
    Who can help?
    Anton
  2. Bruce Lancaster
    Bruce Lancaster
    I'm wondering if that donut is the same as the sort used on Cad front mounts in the forties...if so, i believe it is still available. If not...maybe a '48 Ford donut could replace it.
  3. Get some neoprene rubber of the proper thickness and cut one out yourself.
    Use a hole saw for the intitial cutting out, then put in the freezer overnight for drilling to the proper bolt size.
    Have your clamps and jigs ready to go when you take it out of the freezer, they come up to ambient pretty fast.
    Alternatively, you could cut a mount biscuit out of UHMW.
    That's even easier then rubber.
    Fwiw - I made and ran neoprene biscuit trans mounts for my 50 Plymouth coupe that look very much like your sample in the pic and no problems.
    Neoprene appears to have the same durometer (hardness) as original Ford engine mounts - 48 biscuit style and the Plymouth biscuits.
    I also run UHMW motor mounts in my 32 roadster, no problems there either.
  4. anton
    anton
    Thanks,
    It is not the same as a 1948 ford engine mount, this one is hollow.
  5. anton
    anton
  6. Bruce Lancaster
    Bruce Lancaster
    I just did some thrashing around on the NAPA site with '47 and '49 Cad stuff, which I think is likely the same donut you need. Their listings on older stuff are very incomplete, but when I did a keyword on engine mount some generic donut labeled for "Power equipment" popped up for like $3...it did look a good deal like the Cad one! Anyway, I pretty sure I have a modern PN for this somewhere...will chase it tonight.
  7. squirrel
    the 55-57 chevy car and 55-59 chevy trucks use 8 donuts of two different sizes on the front motor mounts...yours looks like maybe the same size as the smaller one...but if you told us the dimensions it would be a big help!
  8. anton
    anton
    thanks you all
  9. anton
    anton
    It measure 2 3/4 inch wide
    1 1/8 inch thick on the edges and 7/8 in the middle
    hole is 7/8 deep and 9/ 16 diameter
    hope this will help
    Anton
  10. squirrel
    I looked at the mounts used on the old trucks, they are a bit too small.
  11. anton
    anton
  12. anton
    anton
  13. Bruce Lancaster
    Bruce Lancaster
    Still looking for mt cataloging.
  14. anton
    anton
    ok, thanks Bruce
  15. Bruce Lancaster
    Bruce Lancaster
    Found the wrong mount catalog...have one more hope, sp still digging. Still think this is same cushion as Front '36-48 cad, and surely someone makes that...
  16. anton
    anton
    thanks Bruce
    Will ask around and browse the internet for a picture.
    anyone on the HAMB has a picture of a 36-48 Cadillac mount?
  17. squirrel
