Need help idenifing a rear end
Discussion in 'The Hokey Ass Message Board' started by Psycho Kustoms, Mar 2, 2010.
  1. Psycho Kustoms
    Psycho Kustoms
    anyone know what this rear possibly came out of? and estimated year, it looks like it had ears on the pumpkin for trailing arms like on a monti or a cutlass.....
  2. HEATHEN
    HEATHEN
    from SIDNEY, NY
    8.5 inch 10 bolt, came in numerous '70s/'80s G.M. cars and trucks. I don't know if the "A" cast in it means A body or not. Take the cover off and look at the ring gear; many times, along with the part number and ratio numbers, there's a build date stamped on it, like 4 72, meaning April 1972.
  3. Psycho Kustoms
    Psycho Kustoms
    awesome....thank you so much.so brake parts should be easy now....how durable are these rears?
  4. Ratroddude
    Ratroddude
    Cant identify that rear end , but , this one looks a little more appealing..
  5. Parts Man
    Parts Man
    They are very durable. I had one in my '86 Grand National. Parts should be easy to get for it.
  6. About the equivalent of a FoMoCo 8" or a Dana 44..they hold up reasonably well on the street. With a ton of torque you might have some issues, though the small U-joints are just as likely to go. They have been known to hold up surprisingly well in certain race cars, with some work.
  7. SWIGJ
    SWIGJ
    from JASPER GA
    On the r/h axel tube should be some numbers and letters stamped in it. It is usually on the front or top about were the bracket has been added.
  8. THE_DUDE
    THE_DUDE
    When ya find her send er my way
  9. Psycho Kustoms
    Psycho Kustoms
    i was always under the impression the 8.5 had a rounder diff cover.
  10. Will that rear end take a 9 inch??
  11. Psycho Kustoms
    Psycho Kustoms
    I dont fold it in half for anyone.....LOLOLOL:eek:
  12. MBog
    MBog
    I think it looks like a 7.5, skinny axles, S10/15 pu. Lay a tape measure on the cover...
  13. Dzus
    Dzus
    I think I'm seeing the 7.5 'fangs', not the square 8.5 'lugs'...
  14. Psycho Kustoms
    Psycho Kustoms
    im seeing the same.....dont think it was an S-10 though.....im thinking cutlass or something....it looks like someone cut off the "ears" off the top of the pumpkin.
  15. Psycho Kustoms
    Psycho Kustoms
    the OD of the axle housing is 2.75.
