Hi guys, I need some help with this one. The tag reads: Hayes body corp #6732 Model 92 Type 40 Series 78 I'm trying to attach pictures...
I will have to look and see if it match's a cowl I have, 27 Hudson. The trim and cowl vent seem to be the same.
1928 Marmon "78" series had a overhead valve straight 8. That was a tough one, 29-30 Auburn sedan, 28 Pontiac and 29 Reo have similar belt line details. But only the Marmon has a "78" series car
I'd expect the higher-end cars to be constructed differently. A coachbuilt cowl would have a factory firewall - possibly fabricated from flat sheetmetal rather than stamped - mated to an aluminium-skinned body, in which character lines etc. might likely be separate pieces affixed to the skin rather than pressed in. I'd suggest that whatever this comes from was made in fair volumes, with a majority of factory bodies. (Of course "volume" meant something different in 1928. Less than a thousand might have been enough to cover tooling.)
Even the trim at the rear of the hood looks right for a '28 Marmon 78. Looks like Studeynut nailed it! Nice Job! http://cl***iccarslist.com/other-makes/26449-1928-marmon-model-78.html
I can't identify it but if you build and want to set your engine back you can turn the firewall around like on a 30/31 A for a little more room.
Thanks guys!! Looks like a 1929 Marmon series 78 For sure. You bet ******, a firewall flip would work well, it has steering column cutouts on both sides. (LH or RH drive)
Yeah, I would guess those things welded at the "A" pillar area were mirror sanctions. A lot of luxury cars ended up as farm trucks in the depression.
