Technical Need help identifying blower plate
Discussion in 'The Hokey Ass Message Board' started by ciscokid, Oct 5, 2022.
  1. ciscokid
    ciscokid
    16650121137045035053931987067532.jpg 16650122042507154696456026166495.jpg 16650121502031778166690883596200.jpg This plate was gifted to me by a good friend. The brand looked to possibly be "Thompson" ? Someone had machined some of the fins off at some point and only left the "N". There is an accessory drive (snout) casted into the plate as well. I'm pretty sure it's a back plate to a blower. Anyone out there know?
    Thanks
    Deuces and Desoto291Hemi like this.
  2. Beautiful piece,,,I’ve seen similar parts that were used to drive a fuel pump from the back plate .
    But,,,usually the drive for a pump is 3/8 hex spline .
    The tooth count on the gears are 12 and 24,,,,,so it would reduce the ratio to half speed .
    It’s still a beautiful piece .
    Tommy
    Deuces, ciscokid and gimpyshotrods like this.
  3. gimpyshotrods
    gimpyshotrods
    I wonder if that was on the front of a Potvin setup.
    Ends with an N.
    Pumps were out that way.
    Deuces, ciscokid and Desoto291Hemi like this.
  4. ciscokid
    ciscokid
    "Potvin"!!!! Very possible!
  5. gimpyshotrods
    gimpyshotrods
    A little closer:
    Deuces likes this.
  6. Fordors
    Fordors
    The four bolt mount for the pump made me think of Algon, they used an aircraft pump.
  7. gimpyshotrods
    gimpyshotrods
    That is the closest so far.
    That's probably it.
    Desoto291Hemi, Deuces and ciscokid like this.
  8. ciscokid
    ciscokid
    Holy ****! That's it! I knew you guys would know! Thank you! Now I need to locate the rest of it!
    SEAAIRE354 and Deuces like this.
