Technical Need help identifying brakes
Discussion in 'The Hokey Ass Message Board' started by Wizard1926, Jun 25, 2023.
  1. Wizard1926
    Wizard1926
    Howdy, Have a 26 Tudor that the front brakes have been converted to disc. Trying to figure out exactly what I have so I can replace the pads and 1 rotor is slightly warped. Can feel it during braking. Hoping that someone might recognize what kit this might be, our advice on how to research. Looks to be original T axel.
    Thanks in advance
    Bill 20230625_101155.jpg 20230625_101213.jpg 20230625_101450.jpg 20230625_101424.jpg 20230625_101208.jpg 20230625_101454.jpg 20230617_163004.jpg
    dana barlow likes this.
  2. miker98038
    miker98038
    Post the distance between the mounting bolts on the caliper. I just went thru this last week on a friends car, the distance seems to tie it down between the various possible choices.
    GM being the most widely used in kits.
  3. Wizard1926
    Wizard1926
    Thank you ! I will measure and post what it is.
  4. Doublepumper
    Doublepumper
    from OR-WA, USA
    You probably know this, but I just gotta say it...left side hose is shot. This is interesting :
    Might check it out. Good luck!
    Budget36 likes this.
  5. Wizard1926
    Wizard1926
    I am going to pull the calipers this next weekend, clean them up and paint. Will see if I can locate any numbers and check caliper mounting bolt spacing
  6. Mr48chev
    There are about 3 different GM single piston caliper designs between 1972 and the mid/late 80's rear wheel drive cars. I'm thinking that you have 69/77 GM mid size, Camaro, Nova size calipers. Those are 7- 1/16 center to center on the mounting holes.
    The Wildwood diagram for GM metric is below. 5.46 center to center. GM-Metric-Iron_Single_Piston_Floater-cm-lg.jpg
  7. Wizard1926
    Wizard1926
    Thank you very much for the great information. Would I ***ume that the hubs and rotors would be from the same GM era ?
  8. alchemy
    alchemy
    Just an FYI, the hard lines are not supposed to end in mid air and the hose attach there. The end of the hose needs to be securely clipped into a hole in significant steel. Then the hard line can screw into it.
    bobss396, Happydaze and Budget36 like this.
  9. Wizard1926
    Wizard1926
    Thanks Alchemy, didnt even notice that. I'll take a look.
  10. Wizard1926
    Wizard1926
    I'm guess the area you circled would be a bad king pin or spindle ??
    Thanks
  11. hoop
    hoop
    Depending on your wheel bolt circle ,the rotors could be Camaro or Volare -Aspen.
    31Apickup likes this.
  12. bschwoeble
    bschwoeble
    Not a "T" axle.
  13. Wizard1926
    Wizard1926
    If not a T axel, then what do you think it is ?
  14. alchemy
    alchemy
    To me it looks like a Model A axle (has lead a tough life), with 40 Ford spindles.
  15. Day 2
    Day 2
    from ga
  16. Fordors
    Fordors
    I know your topic in this thread is brakes but can you show us how the rack and pinion steering is hooked up to the column?
  17. Wizard1926
    Wizard1926
    Yes, I'll try and get some pics tonight and post them
  18. Wizard1926
    Wizard1926
    Thanks, yep the guy I hot it from didnt slow down for potholes or speedbumps....
  19. Wizard1926
    Wizard1926
  20. Wizard1926
    Wizard1926
    Looks like the calipers are mid-size chevy 69-77.
    Would it be safe to ***ume that the brake rotors/hub will be the same ?
    Thanks
  21. Moriarity
    Moriarity
    SUPER MODERATOR
    please do not post pictures of the rack and pinion steering, that is off topic here
  22. alchemy
    alchemy
    No. It’s very common to pair up rotors from something entirely different.
  23. Wizard1926
    Wizard1926
    That's what I was afraid of. Guess I will see if there are any markings on them. Thanks !
  24. Wizard1926
    Wizard1926
    Thanks ! Dont want to get in trouble
  25. nobby
    nobby
    Hello
    take a wheel off
    you have dual drilled wheels in 4.5'' and 4 3/4'' pattern
    IF the wheel bolts to the narrow 4.5'' pattern you are volaire rotor
    raybestos part number i think 7032R
    or specifically 1975 dodge charger to get a one year search
    IF as I suspect it is on the wider chevrolet pattern of 4 3/4'' pcd
    then you have the 70-77 chevrolet rotor
    i think the part number is 5214R raybestos. - i cant remember
    I suspect they are chevy rotors as they run a 7.16 stud and it appears in the pics that someone has run 1/2'' unf bolts through from the rear - no no
    they both measure 11 inches in diameter
    the chevy has a narrower hat than the volaire.
    the volaire will be 1/2'' unf
    when pulling the wheel take a pic of the rotor snout as its easier to see what you have
    to be certain its the chevy or volaire
    YOU MUST make sure you get the correct ones as the inner bearing cup and cones differ
    pull the rotor off one side and look see if you have these on the spindles
    if you have you can run either brake rotor
    you will get in a world of pain finding out what cup goes with the cone.
    IF you run the chevy rotor and fit the volaire, you track will widen each side by 1/2 inch
    the same happens if you are on chevy and fit volaire, you widen 1/2 inch a side
    if that was mine and because its a 26 with high fenders and you can see in almost, it would be getting these
    oh and especially as you have stock spindles and could run the stainless ****on heads in at all 4 points......
    you will probably spend 100 bucks on discs pads and bearings
    that so cal kit is 720 dorra
    plus you will need to have new m10 1.5 brake lines made for the banjo m10 to sae
  26. nobby
    nobby
    oh and while I am on.....
    the cotter pins holding the king pins in the axle....
    the head on the side ion the picture has been sunken in, they have to be exactly the same depth side to side or else it is indicative of it being eaten by worn pins
  27. Wizard1926
    Wizard1926
    Wow nobby! Thank you so much for the tutorial and GREAT information. You have helped me in my quest of these front brakes tremendously!
    I feel confident that I can pull one this weekend and figure out what to order as replacements.
    I am also going to look at the king pin situation you are talking about, do you think I need to invest in king pins ? Wanna keep this thing safe.
    Thanks
    This is a great site. Everyone has sure been great about sharing their wisdom and advice
  28. Wizard1926
    Wizard1926
    Going to start inspecting the king pins this weekend. What do I look for and where to find replacements if needed ?
    Thanks
    Bill
  29. alchemy
    alchemy
    With the weight off the wheel, grab and see if you can rock it up and down any. Shouldn’t be any slop at all.
    There are hundreds of old Ford parts vendors that can sell you some 40 Ford kingpins. But after you pick one, ask here if they are reliable.
  30. Wizard1926
    Wizard1926
    Thank you very much Alchemy
    Appreciate everything.
