Technical Need help identifying calipers
Discussion in 'Traditional Hot Rods' started by Yamanine, May 4, 2021.
  1. Yamanine
    Yamanine
    Anyone know what these calipers are off of? Their good, I just need to get new pads.
  2. fabricator john
    fabricator john
    from venice fl.
    stock mustang 2
    fabricator john
    miss you dad
  3. Yamanine
    Yamanine
    Thanks John, I was thinking Mustang II but I have not found a picture of any Mustang II, or Pinto anywhere that looks like these. The pads are different, the bolt holes are different, the pads are held on by some funky metal clips.
  4. squirrel
    try 72 mustang (before the II came along)
  5. Yamanine
    Yamanine
    Thanks Squirrel, that led me to it! It's 68-73 Ford Mustang, Torino, Falcon, etc.
  6. HOTRODRONNY
    HOTRODRONNY
    Is it the GM metric caliper
  7. 57 Fargo
    57 Fargo
    Uhhh...nope, it was already identified in the post directly above yours....
  8. 31Apickup
    31Apickup
    I think that is an old Super Bell set up, they made one that used the 71-73 Mustang caliper, and the Mustang rotor which mounted to the Super Bell hub
  9. 31Apickup
    31Apickup
    squirrel likes this.
  10. Interesting.... Looks like they deleted the 'stabilizer spring' in the conversion. Look here:
    https://www.rockauto.com/en/moreinfo.php?pk=2027358&cc=1132467&jsn=593
    Those would be the two large silver brackets as seen here and their job was to keep the caliper from '****ing' and wearing the pads at an angle. This was a real problem on these even with the stabilizer and Ford changed to the 'sliding' caliper design in '74 to address it. With that missing, make sure the caliper anchor pin bolts are unworn, straight and clean, and the rubber bushings should be replaced if loose or damaged at all. Lube the anchor pins with a dab of brake grease when installing.
  11. Mr48chev
    The spring that retains the back side pad is an instant indicator that the caliper isn't any sort of GM.
    If memory serves right those kits came out before the GM caliper kits did for hot rods.
  12. X38
    X38
    Yep, mid/early 70's. Available via Pete&Jakes etc.
    I had a locally made version, I used early 70's Falcon parts.
