need help identifying spindles
Discussion in 'The Hokey Ass Message Board' started by unrulyprocuda, Apr 22, 2013.
  1. unrulyprocuda
    unrulyprocuda
    below are pictures of the straight axle on my g***er they are 5 on 4.75 chevy bolt pattern im wanting to change the drums to disc but dont know what year to get that will bolt on and be able to use my spindles i was told it was 47ish chevy truck maybe older i need your expertise to tell me what to get and possibly where and what to buy thanks.
  2. 296 V8
    296 V8
    from Nor~Cal
    Most likely 53 - 54 chevy car on pickup axle and spindles …….. You should ask on the main page.
  3. 24riverview
    24riverview
    First guess would be truck, is the axle straight between the springs? Cars were not. If you can find a number on the spindle you should be able to identify it here- http://chevy.oldcarmanualproject.com/parts/1929_54/381.htm
    Is that number in the last picture 3656872? If so it's 41-53 1/2 ton.
  4. need louvers ?
    need louvers ?
    If I remember my Chevy stuff correctly they are Chevy truck from '47-'59 or so with '53-'54 chevy p***enger car brakes. In either case Speedway can help with disc brake kits along with a whole bunch of other companies as well.
  5. BootleggerMatt
    BootleggerMatt
    Looks just like a 1949 chevy truck axle I used to have. The shock mounts and drag link bracket are custom.
  6. theHIGHLANDER
    theHIGHLANDER
    I have the same get up. Those are early p***enger car brakes and backing plates. I can't raise my right hand as to the spindle origin, but I believe it is early PU.
  7. unrulyprocuda
    unrulyprocuda
    Thanks for all the advice this helps i will take them apart now and attempt to buy disc brakes
  8. 40Standard
    40Standard
    from Indy
    welcome to the board
  9. 33sporttruck
    33sporttruck
  10. 55 Mercury
    55 Mercury
    Looks like 47-54 Chevy pickup axle. Kingpin dia should be .866
  11. ChopTopJimmy
    ChopTopJimmy
    Hey Unrulyprocuda, Do an intro... Follow the rules of the board please. CTJ
