Technical Need help identifying steering column
Discussion in 'Traditional Hot Rods' started by Ben Chirco, Oct 21, 2019.
  1. 31Apickup
    31Apickup
  2. David Gersic
    David Gersic
    from DeKalb, IL
    There’s a long connector about halfway down the column, that snaps in to a bracket welded to the tube.
    The male half of this is either 3 7/8” long (1969-1976) or 4 1/4” (1977 and newer).
    Or, if you’re lucky, like me, it’s about 3” long, because somebody had the wrong parts, so they cut away everything that didn’t fit until they could jam it together and make it kinda work.
    Here’s what the housings look like:
    https://www.americanautowire.com/shop/gm-steering-column-kit-includes-3-7-8-connectors
    Scroll this page:
    http://www.buickperformanceclub.com/tiltsteeringcolumnwobble.htm
    down to the “harmonica connector” picture. That’s what you’re looking for. I’m currently rockin’ a really good head cold here, so not going out to the garage to take pictures right now.
  3. Frank Carey
    Frank Carey
    GM also supplied columns to Jeep. But they all had the illuminated shift quadrant on top like GM vans. But, unlike vans, had key in column like GM cars.
  4. Ben Chirco
    Ben Chirco
    Mine measures 3 7/8".
    I know know where the connector is supposed to be.
    So i guess (1969-1976). Thanks for all the help.
    I will put a note in the file
