Technical Need help identifying transmission chevy
Discussion in 'The Hokey Ass Message Board' started by Medic4lifejr, Sep 12, 2016.
  1. Medic4lifejr
    Medic4lifejr
    hello I am converting 53 bel air to a v8. The cost to rebuild original engine will be more than v8 swap. I need help what transmission I'm looking at.
  2. BJR
    BJR
    I would say 350, but a picture of the whole ****** would clinch it.
  3. Medic4lifejr
    Medic4lifejr
    Thanks for the response, this is what I was sent
  4. 56sedandelivery
    56sedandelivery
    TURBO 400 for the win! Not a lot of long shaft Chevrolet patterns however; most want the short version.
    I am Butch/56sedandelivery.
    clunker likes this.
  5. Mr48chev
    Looks to be a Turbo 400 and the dude on the other side of the p*** types faster than I do
    I can't find the info that ID's the trans from the tag with what searching I did but that length of extension housing usually came with full size sedans and wagons.
    timmy2times likes this.
  6. Medic4lifejr
    Medic4lifejr
    Sweet thanks for the response you guys. From searching here I see everyone with their v8 350 swaps install th350. They are running driveshaft from s10. If I pick up s10 driveshaft, length should be fine correct? Only the yoke need to be changed because the teeth pattern.
  7. BJR
    BJR
    Yup defiantly a 400. Pictures make all the difference.
  8. squirrel
    th350 does not have a tag.
  9. 56sedandelivery
    56sedandelivery
    Initially, I said I thought it was a TH400, and probably still is. But, it could possibly be a TH375; it would take looking at the splines of the output shaft to know that. Or, seeing the underside of the extension housing, where it would say "375". Basically, a TH375 was a TH400 case and guts, with a TH350 output shaft.
  10. inthweedz
    inthweedz
    Electronic kick down on the left rear of the main body??
  11. 56sedandelivery
    56sedandelivery
    72-76 is the information I have on the TH375 transmission, even though the tag says 89 on the OP's transmission.
  12. Thank u im trying to find out what my ****** is on my non hamb 74 nova
    Sent from my LGMS330 using The H.A.M.B. mobile app
