Need help Id'ing 454 blocks.
Discussion in 'The Hokey Ass Message Board' started by Fatman06, Dec 30, 2011.
  1. Fatman06
    Fatman06
    Hello everyone,
    I'm looking for some help ID'ing two 454 blocks that I have.
    Both have a casting number at the bellhousing #361959, which I can have found to be '73-85 blocks.
    What I'm trying to find out is what the stamping on the block forward of the head decodes to.
    the stamping looks like
    block #1 : c9b147053
    block #2 : c6j113382
    both blocks have "high perf p***" stamped in the bellhousing, with
    block #1 also has R8
    block #2 has F3
    Supposedly both of these came out of mid to late '70s trucks.
    Any help, ideas, or links to info on these would be greatly appriciated.
    Thankyou.
    Mike
  2. HotRodTom32
    HotRodTom32
    from DSM, Iowa
    Fella's and Feline's, He IS reading these numbers correctly. I have laid my peepers on 'em also. They do, in fact read:
    I have exhausted everyplace that I can think of to look. I even checked a couple odd places like MerCruiser boats. I struck out. Fatman06 and myself will be rebuilding these. Just kinda wonderin' what's their story.
    HRT
  3. Virtually all BBC have High perf cast in them except tall deck engines and I believe all car engines started with the "C" designation and trucks with "T". I have pulled several BBCs out of mid to late 70s cop cars. The only reason the code would be important is if you are doing a resto as they are fairly generic if they are 2 bolt mains. Good luck.
  4. squirrel
    The numbers you're looking at are the partial VIN.
    C = Chevy truck
    6 = 1976, 9 = 1979 model year
    J = Janesville WI ***embly plant, B = Baltimore ***embly plant
    If you can find the other stamped number that looks like T0513TWB or something, it is the engine number, and gives you the engine plant, engine ***embly date, and suffix code
    look both on the deck surface in front of the p*** side head, and on the little boss above the timing cover
