Hot Rods Need help IDing this truck - 1950 Ford?
Discussion in 'The Hokey Ass Message Board' started by Rj27buick, Jun 6, 2023.
  1. Rj27buick
    Rj27buick
    Hi Guys -
    My niece purchased this truck a year ago without any help! She is unsure what she wants to do - sell or keep. (No this isn't a shameless use of this great site for a sales pitch - I will post it properly when ready if that is her direction). This is a request for some help identifying exactly what this truck is. The person she bought it from said it was a 1950 Ford F1. I did a little research and I am not sure it is an F1 - possibly F2 (3/4 ton). some info:
    vin - 98RD432339 - Registration says 1950 - info I find says "9" up front means 1949 but this carried into 1950.
    Engine - 8BA - and the vin says 8R
    Engine Casting # - 30115-1 (not sure if this is the right number to look at)
    Wheels - 8 lug - F2 or F1 ???
    trans - T87D-1 W.C.Div. SB2 (numbers on the trans)
    What else will help?
    A few pics to follow .....
    As always - thanks in advance for the great info from the experts on this site
  2. Rj27buick
    Rj27buick
    Here are some pics .... IMG_3491.jpeg IMG_3462.jpeg IMG_3476.jpeg IMG_3475.jpeg IMG_3474.jpeg IMG_3470.jpeg IMG_3469.jpeg IMG_3479.jpeg
  3. I believe you have a 50 F2. Based on the 8 lug and smooth bed sides
  4. rusty1
    rusty1
    48-50 with a 51-2 bed is my guess, half ton. very nice.
    Tiny likes this.
  5. I thought the smooth bed started mid 50?
    Turnipseed and charleyw like this.
  6. Bandit Billy
    Bandit Billy
    Curious, Why is she considering selling already? Did she not like driving it?
  7. Budget36
    Budget36
    May want to verify the SN, should be a tag on the inside of the glovebox door.
    But thing is, F1’s were 5 lug.
    I don’t recall the numbering sequence, is hers a state issue ***le from a different era than new by chance?
  8. redo32
    redo32
    Nice truck. From my 70+ years of observation, my neighbor had a '49 F1, which was the year of my birth and I bought my first '48 F1 in '78. All the F2's I remember had long box and large radius front fenders along with the 8 lug wheels. So what we have here might have been a collection of parts. An F2 shortened with new bedsides and F1 front fenders, or a F1 with F2 axels. I'm not an expert on F1 serial numbers, but the frame numbers should determine the beginings.
  9. redo32
    redo32
    A quick search found this
    The first digit is an abbreviation for the year. 8 for 1948, 9 for 1949. The 1949 production sequence continued into 1950 and possibly 1951 (there is some debate here). Serial numbers for 1950 began at 92251 for 6 cylinder trucks, and 73088 for V8 trucks.
    The second and third digits indicate a 6 or 8 cylinder engine. 7H is a 6 cylinder, 8R is an 8 cylinder.
    The fourth digit identifies the model. C=F1, D-F2, Y=F3, F4=T.
    The last 6 digits are the production sequence.
    Bob Lowry and Budget36 like this.
  10. Rj27buick
    Rj27buick
    Thanks everyone -
    I agree I think this is a combination based on my research as well. Could be a F2 (8 lugs) and F1 Bed???? It's definitely a new bed - fibergl*** front and rear fenders. I am not knowledgeable enough to know if there is a difference in the bed between F1 and F2 - although I read F2 was 8' bed. This isn't 8'.
    @Bandit Billy - it's her first standard shift!!!! And she is now planning a family. I know we have all been there. So she isn't sure what to do. I explained that we first need to figure what she has!!!!!
    Bandit Billy likes this.
  11. redo32
    redo32
    Wheelbase of F1 is 114in. F2 is 122in. The frame must have been shortened. That is if the ***le matches the frame. There are letters and numbers stamped on the firewall. The letters indicat the color and the ***embly plant. The numbers are the last digits of the serial number. Is there a tag inside the glovebox door?
  12. clem
    clem
    Beautiful pickup !
    I can’t help with what exact model it is , but I can help with the ‘not sure what to do’ part, -
    If at all possible try to keep it……..
    If not possible maybe she has a family member (hot rodding uncle maybe) who can buy it until she can afford to get it back?
    SS327 likes this.
  13. Squablow
    Squablow
    I think most of the truck engines said 8RT on them and not 8BA (that generally was p***enger car only) but it's possible those were changed out too. Never heard of a short box F2, or an 8 lug F1, so this almost has to have been ***embled from parts. But who would shorten up an F2 but leave the heavy axles? That's odd.
    I'm not sure what's going on here. Nice looking rig, I just wonder what all has been changed on it in its past.
  14. harpo1313
    harpo1313
    from wareham,ma
  15. Rj27buick
    Rj27buick
    @clem - I wish I could take this into my inventory - need to clear a car or two!!!!
    @Squablow - thanks for the engine info - "most trucks had 8RT" on them. I will investigate further.
    again - appreciate the feedback everyone - very helpful
    clem likes this.
  16. Bandit Billy
    Bandit Billy
    Ah, I was asking because I am building a truck for my wife to drive and was wondering what aspect (s) your niece was running into. Shifting is a biggie. Car seats and single cabs are a tough call as well. Not a lot of safety equipment in these. Thanks for responding.
  17. warbird1
    warbird1
    Pull that truck gearbox and put a C-4 in for her... ;)
    '28phonebooth likes this.
  18. 51504bat
    51504bat
    If you're considering the automatic route the 8 lug rear end probably has a pretty low gear set. Go with an AOD instead of the C4. The TV cable will require some thought but its been done. JMO
    warbird1 likes this.
  19. 1952henry
    1952henry
    8RT heads came debuted around 1952. But rebuilders most likely used whatever they put their hands on. Have seen a flathead with 8BA on one side and 8RT on the other.
    can you post a picture of the rear axle? If it is split in the middle, it is a Timken 51524, only axle for the F2-3, it had full floating hubs. The F1 had a Dana/****er 44. IIRC, the 48-49 may have had a 41.
    If you swap transmissions, do not toss the T87. That is a HD 3 speed, synchronizers in 2-3. Was optional in F1s. Guys looking to get rid of the spur gear T9 would be interested. Speaking of that, have a look at the transmission crossmember. The F2-3 crossmember would have a recess for the mount/bearing retainer, bottom of crossmember would have a bolt on plate to access the thick rubber mount.
    alanp561 likes this.
  20. Rj27buick
    Rj27buick
  21. Rj27buick
    Rj27buick
    This is the rear
    B58914BE-525C-4C8C-9B9F-7E3194F048A0.jpeg FCF4D6AD-13AB-49EE-9452-AD0579AE102D.jpeg
  22. onetrickpony
    onetrickpony
    from Texas
    Rear end is a Ford 8.8. It's much newer than the truck. It even has disk brakes.
    alanp561, 210superair and Budget36 like this.
  23. Rj27buick
    Rj27buick
    Thanks - I truly appreciate the help
  24. Rj27buick
    Rj27buick
    Def disc brake. 8 lug is from what?
  25. Budget36
    Budget36
    Can you pop one of the front covers off? Never really looked at an F2 rear axle before, but that looks like a wheel spacer/adapter to my eye.
    Especially the appearance of it looking like aluminum.
  26. 210superair
    210superair
    from Michigan
    That's awesome. Pretty truck. Any lady would buy that, is my kinda lady...
    SS327 and Budget36 like this.
  27. Mr48chev
    Sometimes you have to cheat and sneek over to those who have the good answers . how do you decode a vin # for a 1950 f1 - Ford Truck Enthusiasts Forums (ford-trucks.com)
    The short version is:
    vin - 98RD432339
    9 = year
    8R - V8
    D= F-2
    432339 Production number and that may have been a running production number covering more than one year. As in "We just keep making them and 1949 ends at ____ and 1950 starts with ____.
    Then you throw in a couple of backwards thinking states that registered new vehicles as the year they were sold new in rather than actual production year model. Especially on trucks for some reason. That happend up though the mid 50s in a couple of states. I've seen it on Advance Design Chevys a few times. A hold over 49 got sold in early 50 and was ***led as a 50 while and early production 50 sold in late 49 was ***led as a 49. You can imagine the **** hitting the fan in those states when 53 F100 came out and the state wanted to ***le them as a 52.
  28. 1952henry
    1952henry
    Hopefully picture comes up. This is an F3 frame/transmission crossmember. Perched precariously is the F2-3 rear mount for the transmission. Ignore the hoop on left side. This is a frame from F3 with the Marmon Herrington 4wd conversion. It was notched/re-enforced for the front driveshaft. Just trying to help ID frame.
    Budget36 likes this.
  29. 1952henry
    1952henry
    Have to defer to Onetrickpony for rear ID. The 8 lug has me stumped
  30. nochop
    nochop
    from norcal
    I bet someone made an adapter to use the old style wheels
