Need help in identifying engine
Discussion in 'The Hokey Ass Message Board' started by Second Amendment, Aug 16, 2011.
  1. From my question it's obvious I don't know **** about
    Fords. Pulled it out of a 1989 F350 I s****ped out. Wasn't the original engine.
    390, 427, 428, 429?
    Any help would be appreciated.
    Thanks.
  2. squirrel
    460 possibly 429, but more likely a 460 from the mid 70s
  3. 69supercj
    69supercj
    I'd say squirrel is on the right track, definately not an FE.
  4. squirrel
    Actually I could be way off, it has serpentine belt stuff, but the carb looks old...so you probably need to find as many numbers as you can to figure out what it really is. Could be an 80s-90s 460 from a truck? they went to efi around 86 so it could be converted to carb?
  5. Thanks for the replies. Would casting number off
    manifold work or do I need to find head or block numbers?
  6. Deuces
    Deuces
  7. Kenneth S
    Kenneth S
    The numbers on the block, should be by where the starter is.
  8. squirrel
    I'd look for as many numbers as you can, the first 4 characters are what's important. The numbers look like E4TE which translates to
    E = 1980s
    4 = 4th year of the decade (ie. 1984)
    T = Truck
    E = Engine
    So if you find that the casting numbers are all pretty close, then the engine was probably made the year of the newest casting number, or soon after that.
  9. junkyardjeff
    junkyardjeff
    No EGR and points distributor so it looks pre 73.
  10. squirrel
    yeah, but look at the pulleys and brackets up front, my guess is it's an EFI motor that was retrofitted with carb/ignition from something older. Or vise-versa
  11. Ole don
    Ole don
    If it came from a big truck, it could also be a 370. My guess looking at the carb is 460 with different front brackets, or like Squirrel says, and EFI motor with an older intake.
