Technical Need Help, King Pin Bushings
Discussion in 'Traditional Hot Rods' started by Mike Colemire, Jan 28, 2020.
  1. Mike Colemire
    Mike Colemire
    I need to put king pin bushings in my plymouth, dodge wavey front axle. I found a king pin set, has everything but 2 bushings. I've searched and came up empty, does anyone know or have a link where I can buy the bushings separate?
  2. May be McMasters-Carr,or Dorman by size listing.
  3. seb fontana
    seb fontana
    from ct
    What is the ID and OD of the bushings you got with kit?
  4. Mike Colemire
    Mike Colemire
    I'd have to measure them, hoping someone might have a broken up set that would sell the bushings.
  5. hudsonmand
    hudsonmand
    Perfect Circle ch***is look up by size
  6. 41rodderz
    41rodderz
    from Oregon
    Should be easy to procure from a variety of places . We used to get bushings, o’rings etc from a hydraulic supply place. Machine shop may be another. Maybe a bearing supplier as well .
  7. Mike Colemire
    Mike Colemire
    King Pin is .796, I'll check the Perfect Circle.
  8. Gray Ford
    Gray Ford
    from Illinois
    Try NAPA.......They used to supply king plan bushings seperate ....They look up the kit contents to get the numbers for the seperate parts.....Look for a store with books.....NOT computers.....
    irishsteve likes this.
