i searched the tech archive and all i can find is split bone mounting where the big problem is solid mounting them. i am not mounting them split, and i am using the stock spring perches. so to me it looks like the mounts would be "crooked" on the axle tube, when the perches are paralell. is this correct? and if so can i solid mount them? also, how far apart should the perches be, gettin ahead of myself but i know i have read articles on hear about mounting the rear buggy spring, dos'nt sound real easy!! thanks, travis
Yes they come together at the front. The only seperation was the mounting lug on the bottom of the torque tube. I can measure the position of the axle mounting brackets if you want to run the stock spring. Also the lug width if that is of interest.
