Need Help on 1929 Model A Ford
Discussion in 'The Hokey Ass Message Board' started by old skool, Jul 5, 2008.
  1. old skool
    old skool
    from VA
    Hello,
    Need some advice from you pros out there. I am working on a 1929 Ford Sedan. I am keeping the original 4 banger. This is my first time working on a Model A engine and these types of carbs. When I bought the car gas would come out the carb. This does not happen the whole time it is running. The engine runs fine. I was not sure why it would (I thought the float was messed up). I rebuilt the carb and gas will still flow out while we were starting it (not pouring out). I have many books on the subject, but nothing really goes into real detail to what causes or mentions it. Is my float off? Is this common with these old engines? I am almost finished with it and want to take it on the road, but I do not want a engine fire? I have put many hours into this and dont want to #@$% it up. I could use some real advise. Any suggestions? Compared to the other engines I have worked on this seems so simple. What am I missing?
    Thanks for your time.
    Marty
  2. JohnEvans
    JohnEvans
    from Phoenix AZ
    Well with that updraft carb starting/cranking with full choke sometimes you will get a little leakage out of the carb. Leakage shut off indicates a needle/seat problem. Those cars have a fuel shutoff on the tank,make a habit of using it specialy if parked inside.
  3. fiftyv8
    fiftyv8
    from CO & WA
    I dont know much about them except to say John is right, every time you turn the engine off also turn the tank shut off tap off. I also have a battery isolation switch installed and turn that off as well.
  4. Jalopy Banger
    Jalopy Banger
    from Sweden
    I replaced my fuel shut off, float bowl valve, the punctured bowl and set the bowl at the right height, then the problem was cured.
    I also had to clean the carb very careful, two times.
  5. old skool
    old skool
    from VA
    Thanks for the help. Marty
