Technical Need help on 1950 Olds Slip Yoke
Discussion in 'Traditional Hot Rods' started by inliner2318, Aug 21, 2023.
  1. vtwhead
    vtwhead
  2. vtwhead
    vtwhead
    I have a GM cross reference book that I loaded to a thumb drive that may give some insight. Now all I have to do is locate the drive :rolleyes:
  3. Peter Bowman
    Peter Bowman
  4. christmas tree
    christmas tree
    1949 and 1950 is different than 51 52 53
  5. Peter Bowman
    Peter Bowman
  6. Peter Bowman
    Peter Bowman
    Thanks to everyone here I was able to get a NOS slip yoke that fits perfectly! Appreciate everyone’s input.
    By any chance does anyone know what u-joint would fit? Also, how far in should I position the yoke before deciding how long the drive shaft should be? Half way, 2/3rds?
    Cheers!
    51 mercules likes this.
  7. skooch
    skooch
    Did you get the part that welds to the driveshaft? Are you using a 1950 driveshaft or something newer? Set yoke 3/4” out.
  8. Peter Bowman
    Peter Bowman
    Do you mean the yoke for the drive shaft? No, that doesn't come with the slip yoke, but the shop that I use to make my driveshafts can come up with something. This is on an Allard J2 with a Halibrand QC rear (currently being rebuilt). Once I get the diff back and mounted, then I can calculate the drive shaft length I need. I"m sure I can take measurements and try and find the proper u-joint, was just hoping someone knew off the top of their head what it might be!
