need help on 28 ford raditator
Discussion in 'The Hokey Ass Message Board' started by terry bosman, Jan 27, 2011.
  1. terry bosman
    terry bosman
    please help me save money and do it right the first time I want to put 32 rad shell on 28 model a sedan. can I use a 32 raditator. or what is the best thing to do is aluminum ok? 3 core? or more will be running 302 some what stock with auto. will also have air conditioning. I was told that the hood will have to be change. can I run hood sides with the 302. this site has helped me a great deal. if I could figure out how to post pic I will be proud to show you all pic of my progess. hope to do that soon thank for any and all of your help terry
  2. junkyardjeff
    junkyardjeff
    What ever you do have a correct radiator made for the shell,it might cost a little more up front but it will look nice and not like something that is rigged togather. I have noticed alot of people using those much cheaper mustang radiators but to me it looks like it was built cheap with no thought,you can get by with those radiators if you are using a hood to hide it but if its going to be hood less the mustang radiator looks too tacking in a early grille shell.
  3. seventhirteen
    seventhirteen
    from dago, ca
    early mustang radiator will fit, has right inlet and outlets and can be bought for around $100 new
    stock radiators look better, cost more, even re-coring an original will typically run around $300
    also keep in mind a 32 radiator on a 28 is not a direct fit like it is with the 30/31 model a, 28/29 model a's had a shorter radiator
  4. terry bosman
    terry bosman
    thanks guys. the original will be the way I go. seen it done in pic but would like a little more info. do you use the original size 32 shell or the short one. thanks agian tery
  5. tedley
    tedley
    from canada
    I used a 32 shell over my walker model a rad. Made my own 3 piece hood. Smooth sides, no louvers, and does not over heat with the 302. Stock dropped headlight bar goes thru the 32 shell. I did this by cutting it in two, threading the bar on one end, welding a long bolt in the other. The long bolt was indexed so when it was screwed together the two halves where tight and headlights sit straight up. A small washer can be used as a shim to dial it in.
