Technical Need help on speedometer speedo
Discussion in 'Traditional Customs' started by Colin jarrell, May 7, 2018.
  1. Colin jarrell
    Colin jarrell
    I own a old 78 Ford f150 and the speedometer is doing the normal go 80 when your doing 20. It needs lubercated. I've already used dry graphite and it does NOT WORK. does anyone know a liquid graphite lube I can use for the wheels of the speedometer?
  2. tb33anda3rd
    tb33anda3rd
    is the cable noisy? i just use a light grease to lubercate the cable.
  3. Budget36
    Budget36
    Nice TB...and no slam?
    OP...head over to FTEenthusists.com? might get ya on the right path.
  4. tb33anda3rd
    tb33anda3rd
    i did spell it lubercate
    Budget36 likes this.
  5. I thought TB was going easy on him being 16 years old
    Budget36 and tb33anda3rd like this.
  6. Colin jarrell
    Colin jarrell
    The speedometer doesn't work, the outer wheel is meshing too much with the inner wheel. Needs a liquid graphite lube to help with some slippage...
  7. Budget36
    Budget36
    Young man, I'm not the HAMB police, but do need to tell you that you're not in the right internet board... Search for Ford Truck Enthusiast ...I can't recall the www thing...but you'll fit right in there.
    Best of luck!
  8. Mr48chev
    Here, https://www.ford-trucks.com/forums/ There is a section for all Ford Truck year models there.
    What Budget36 was referring to is that we have a pre 1965 Cut off year model thing here. The vehicle has to be 1964 year model or older or in a few rare cases have the exact same body style as a 64 or earlier. Your "old" truck is a new truck as far as this board is concerned. Actually it is a year newer than my "late model Off Topic" truck.
