NEED HELP! PLEASE!!!!Broke hot rod!
Discussion in 'The Hokey Ass Message Board' started by Hemirod, Aug 4, 2009.
  1. Hemirod
    Hemirod
    from TX
    I have a 1930 Ford roadster with a 392 Hemi. I am having a problem that makes no sense!! I have injoyed the car running for 3 years without any problems, until now. I was driving the car at the Lone Star Round Up, in the rain and it started to miss very bad. I seemed to only have been running on a few cylinders. I played with the timing and the fuel regularor, but nothing made a difference. I changed the plugs at the hotel and she was back in action, but shortly it did it again (two more times). I figured it must be a weak coil with the distributor I was running, so I ordered a new one. In the mean time, I noticed that if you plugged a timing light to the alternator and squeased the trigger, the engine would run right. (Weird!) I changed the distributor to a Joe Hunt and it still did the same thing. I changed the alternator to a new bigger one (I also put in a new larger battery). The car seemed to run better, but still not right. Now you can start the car and keep the RPMs up at about 2000 until it smooths out. Only then can you let off and it will idle. If you don't, it just dies. This is where it really gets wierd. If you start the car like I just said and immediately kill the battery kill switch, it will idle just fine. Only thing is the tac jumps a bit. The only thing that the switch shuts off is the positive on the battery. I have also put a new fuse block, wired a new key switch and re-cleaned the ground connections. I have no idea what else it could be. Please give me some ideas! Thanks for all your help. By the way, this car has about as bare bones as you can get as far as wiring goes. Also the lights are always bright.:confused::confused:
  2. Falcon
    Falcon
    from nevada
    Did you get water in the gas.?
  3. Hemirod
    Hemirod
    from TX
    No, Drained it and put a new fuel filter in too. Fuel tank is in trunk. Thanks
  4. Falcon
    Falcon
    from nevada
    Sounds like a short somewhere under the hood. Any plug wires bite you?
  5. Falcon
    Falcon
    from nevada
    Wires to the dist. all good?
  6. Falcon
    Falcon
    from nevada
    Looks like a nice car, are all the fire wall wires going though a gromet?
  7. Falcon
    Falcon
    from nevada
    Was the top up when it stared raining?
  8. hudsoncustom
    hudsoncustom
    Did you try plug wires? Sounds like they might be arcing.
  9. DonMan
    DonMan
    Sounds like a possible ground problem or more like a direct short. Have you traced all of the wires going to coil, distributor, ignition ?
    Where in Tx are you ?
  10. Falcon
    Falcon
    from nevada
    I could keep guessing. You may have fixed the original problem. And know need to dail in all the fixes..?
  11. topdeadcenter
    topdeadcenter
    This is my guess too. Also could be a wire going to the coil that has come loose or has a break in it.
  12. squirrel
    yeah, just keep touching wires and stuff on the engine (running) until you get bit, there's your problem!
    or look at the running engine in the dark...
  13. ablebob
    ablebob
    Sounds primary voltage related. Check voltage at distributor. Check ballast resistor ( if your system uses one ) Check distributor, alternator & block to ch***is ground. Could be dirty contacts in ignition switch. Try to "hotwire" it as a test.
  14. Hemirod
    Hemirod
    from TX
    It does have new plug wires. Yes the top was up when it started raining. It has a second new Joe Hunt set up with new coil built in. I have chased every wire and found no problem. It makes no since at all to me. I changed the ends on the battery cable already, but tomorrow I am going to change all the cables and maybe run an extra ground cable to the engine. I think what was said that I may have fixed the problem and just need to dial in everything sounds good to me. I will go over everything again tomorrow and I will let you know what I end up with. Thanks for all the help everyone! By the way, I am near Houston.
  15. Hemirod
    Hemirod
    from TX
    This sounds like a good idea. I will give it a go tomorrow night too. Thanks!
  16. Hemirod
    Hemirod
    from TX
    I did check all of it and even called Joe Hunt to verify my findings. I agree with what you say, the car just does not want to let go of her illness. Maybe she is pissed about my new car coming. LOL
  17. Falcon
    Falcon
    from nevada
    Maybe the rain was a coincidence. Were you getting on it when it started running bad?
  18. 325w
    325w
    Maybe an over ctimped wire terminal at the coil.
  19. Homemade44
    Homemade44
    Based on what you have said about the timing light and the battery kill switch your problem is in the wiring coming from the alternator and returning to the battery or the main positive wire from the battery. There is a short in that wiring somewhere.
    One way to check that would be to disconnect the battery and alternator and use a good set of jumper cables connected to the starter positive and ground to the engine. If it runs good then it is probably in the feed back from the alternator to the battery. If it still runs bad disconnect the main line from the battery to the started and try it again. If it runs good then the problem is in the main positive wiring from the battery.
    If that doesn't work do what Squirrel said.
  20. superbeeme
    superbeeme
    from georgia
    I'm with the ground guy. I think the problem is in the electrical sys. faulty grounds cause funny things to happen to good cars.:cool:.
  21. Hunt w/Internal coil? Is it based on HEI? IF so, try running a #10 wire from the battery to the + term on the dizzy and see if that helps. Also, make sure the coil housing has a GOOD ground.
  22. 32ratsass
    32ratsass
    Might try a "fine mist water spray" with tap water from a spray bottle, in the dark, and watch for arcs, and listen for engine changes. Works well sometimes!!!:)
  23. skip86
    skip86
    from Florida
    I Read your post on the problems that you are having,disconnect the Tach,what the heck you have tried everything else,as silly as it seems i had a boat with a small block chevy in it,a real nice newer boat,anyway it drove me nuts for 2 weeks,finally out of desperation i disconnected the Tach,ran fine,replaced the Tach,ran fine,sold the boat,boat ran like ****,hard to start,and when it did it ran horrible.just a thought ,good luck.Gerry:confused:
  24. Hemirod
    Hemirod
    from TX
    The car does not have an electric fan on it or any other electric powered item. I am going tonight go over every wire one more time, then change all battery and ground cables. If it still is doing it I am going to print out this post and go right down the list. I really appreciate everyone’s help!<O:p</O:p
  25. Phil1934
    Phil1934
    Unhook the tach. I had one short out.
  26. FANTASY FACTORY
    FANTASY FACTORY
    your alt. is overcharging, you say you changed it, seperate reg?.
    I bet it will run right with the headlites on also,
  27. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    It is my guess that it is your alt. Disconnect it and see how it runs. If that is not it then start to disconnect things until you find what it is. I mean everything, Lights switches everything. Water has got someplace it shouldn't. Also keep a can of WD40 handy and when you think something is it spray it with WD40 and see if it clears up.
    Good luck
    Fuzzy
  28. Hemirod
    Hemirod
    from TX
    With the battery on, you can turn on the head lights on and it will kill the engine. If the battery is off it will not. Go figure.:confused:
  29. Falcon
    Falcon
    from nevada
    Light wiring/switch has a short.
  30. Falcon
    Falcon
    from nevada
    between switch a lights sounds like..rusty plugin/bulb.?
