Hot Rods Need help please
Discussion in 'The Hokey Ass Message Board' started by pie pie, Mar 30, 2011.
  1. pie pie
    pie pie
    from missouri
    Ok so I'm trying to get the car ready for the wedding on saturday so I thought I would put new plugs and wires on it while swapping to the large male terminal cap and from my stupidity I got two wires crossed and it back fired. Swapped back the old wires and cap and it backfired once more. Checked to see if it had jumped timming and does not appear to have. It kind of fired but didn't take off and run. Does anyone have any ideas? Flooded maybe? I'm going to go out before work and see if it will start. I think I may have cranked it too many times.
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    What make of car? Engine? yadayadayada.
  3. pie pie
    pie pie
    from missouri
    63 galaxie with a 66 390. Weiand intake. New eddy 600 carb.
  4. pie pie
    pie pie
    from missouri
    I hope it didn't jump timing.
  5. randydupree
    randydupree
    from archer fl
    put the wires in the correct order.
  6. Saxman
    Saxman
    Yep, check the firing order. Make sure you have the direction of rotation correct.
  7. MeanGene427
    MeanGene427
    from Napa
    Does it seem to be spinning faster than normal? If it has a lot of miles on it, the timing chain may have jumped- especially if it still has the plastic-toothed cam gear- most of the teeth may be in the pan
    Or you may have just flooded it, if you were pumping the throttle while trying to start it
  8. Exactly.
    I had been building GM motors for the local short track guys back in the '80s. Swapped engines in my "Ford" parts hauler and decided to replacecap rotor plug wires etc while I as at it. Wired it and fired it just like I would have done one of the shrt track motors only using the Ford firing order. It ran but just barley and popped and farted.
    I was scratching my head when a friend came by and said which way does your dizzy turn. Then grinned. DOH :eek:
    Your 390 dizzy turns counter clockwise.
  9. pie pie
    pie pie
    from missouri
    15426378 is the order I got off line. Followed the diagram. In counterclockwise
  10. Mr48chev
    Ok, so you should have it with 1,2,3,4 up the passenger side bank while 5,6,7,8 are on the drivers side bank front to back. That can throw guys who are used to GM or Mopar firing orders.
    http://boxwrench.net/specs/ford_352-428.htm
  11. pie pie
    pie pie
    from missouri
    Yep that's how it's ran.
  12. pie pie
    pie pie
    from missouri
    It spins the same as before
  13. it ran ok before you installed new plugs/wires/cap...correct?
  14. handyandy289
    handyandy289
    from Georgia
    Check that you have #1 in the right hole. Bring #1 up on compression stroke, allign timing mark and pull dizzy cap. Rotor should be pointing at the #1 position. Good luck.
  15. Saxman
    Saxman
    Yep, that's the next step,****uming you have the
    1. -firing order correct
    2. -the rotation correct
    3. -the numbering of the cylinders correct
    You have to make sure you have number 1 in the right position on the cap and then check the timing as stated.
  16. pie pie
    pie pie
    from missouri
    #1 is about at 1:00 looking at it from the front. It is spinning counterclockwise. If it flooded how long do I need to let it set?
  17. handyandy289
    handyandy289
    from Georgia
    Hold the gas pedal to the floor and let the engine turn over about 10 or 15 times. If the engine continues to back-fire through the carb then you have the cap wired in the wrong order or in the wrong position.
  18. pie pie
    pie pie
    from missouri
    Since I have tried to get it running it has only backfired twice. It ran great before
  19. Missouri is a big state how far from me are ya?
    Sounds ti me like you have a wire or two in thw wrong place. bring it up on TDC #1 and redoo it from scratch.
    If you prop you carb open it will clear after flooded in a few minutes even if you leave it along the fuel will evaporate in half an hour or so.
    You have an electronic dizzy right? When you switched caps you also switched rotors as well? You checked to make sure that the rotor is fazed right? These are just questions to help you think.
  20. pie pie
    pie pie
    from missouri
    No it's points. Yea I changes the rotor
  21. pie pie
    pie pie
    from missouri
    Got it running. For starters some idiot had a wire from like a old speaker or something to the points from the coil. It only had 2 tiny strands making the spark. And second it was so flooded that I had to put the old plugs in it and clean the new ones. Now it runs good.
