Need Help Reading Spark Plugs
Discussion in 'The Hokey Ass Message Board' started by unkledaddy, Jan 2, 2010.
  1. unkledaddy
    unkledaddy
    SBC, Vortec Heads, RPM Air-Gap, Edelbrock #1806, MSD Ready-To Run with Autolite 103's.
    Plugs 2, 4 & 6 are all a bit richer looking in person, with #6 being the
    richest.
    Plugs 1, 3, 5 & 7 look the same as plugs 2 & 4.
    Plug #8, vacuum leak or what?
    Thanks for any insight.
  2. Mr48chev
    Two and four look about like what I would want to see on today's gas. Number 8 sure does look like it was running lean on that cylinder.
    The vacuum port is in the #8 runner. I'd be checking down stream from it if you have a vacuum line connected to it as there may be something else causing a vacuum leak like a diaphragm in a heater or defroster control.
  3. brigrat
    brigrat
    from Wa.St.
    If an auto and has a vacuum modulator check it and your vac line..........
  4. Special Ed
    Special Ed
  5. unkledaddy
    unkledaddy
    I am only running two vacuum lines. One goes to the vacuum advance from the front of carb (full-time vacuum port), and the other goes to the auto-trans modulator from the vacuum fitting on the rear of the carb. The intake runner vacuum port is plugged.
  6. jambottle
    jambottle
    Bad plug wire on #8.?make sure there is no ideling time before reading plugs.that is cut ignition under power.
  7. unkledaddy
    unkledaddy
    Forgot to mention the pix are from the idle circuit.
    Wouldn't a bad plug wire leave carbon build-up or residue 'cause it wasn't burning off?
  8. unkledaddy
    unkledaddy
