Need Help! SBC Injection Intake Identification ???
Discussion in 'The Hokey Ass Message Board' started by 392sniffin6, Feb 3, 2010.
  1. 392sniffin6
    392sniffin6
    Hi Everyone , on a recent Hemi parts search I came across this Chevy Small Block Cross Ram Injection set up. I can not find any info anywhere on this manifold after hours of searching I am still lost on who could have made this. There is no names are markings anywhere. There is a serial number that appears to be similar to GM casting numbers but I am not sure. I am a Hemi guy and I am a little lost when it comes to SBC's. Any info would be helpful. [​IMG]
    [​IMG][​IMG]
  2. 392sniffin6
    392sniffin6
    Ok one person Pm'd that this might be a Marine set up. Just thought that my ring a bell with someone.
  3. revkev6
    revkev6
    from ma
    kind of looks like a variation on the GM cross ram injection manifold.
  4. propwash
    propwash
    from Las Vegas
    Whenver I see rough-cast but operable intakes with GM-type casting numbers I am put in mind of all the slick stuff that Smokey Yunick did for the performance dept under the cloak of research. This is a utilitarian-looking (not finished for sale) unit that could even have been fabricated for early Corvette racing cars (Gran Sport?). Merely supposition on my part, mostly because prototypes are typically unbranded and unpolished, as are competition-specific parts. Lot of stuff went out the side door of GM during the racing ban days....
    dj
  5. 392sniffin6
    392sniffin6
    Thanks guys for your input! RevKev6 I think you are right this does look like a variant of the setup you posted. When was that manifold produced? I have never seen one before.
    Propwash I like your story side door Prototypes I appears to have ran at one time but with minimal use. I wonder who's project this was?
  6. Flipper
    Flipper
    from Kentucky
    No throttle blades?
  7. 392sniffin6
    392sniffin6
    No Blades, I was thinking that maybe the runners on each side went went into into a larger plenum with some type of throttle body but I am only speculating.
  8. David Pozzi
    David Pozzi
    the /00 part number looks like a GM prototype marking.
    These were mainly used on Indy stock block engines. I think the lack of throttle blades or carb mounts indicates it was set up for a turbocharger with a single throttle valve farther upstream. Nozzle sizes would tell you if it was set up for Methanol or gas. Most likely Methanol for Indy cars. Some of these wound up in the hands of boat and circle track racers, but I haven't seen one like yours before. They have a restriction to flow where the runners cross each other and I don't think they flow as well as downdraft intakes. The runners are also "interlaced" which makes one runner go around the opposite one. You have one runner with a good port approach, the other is not-so-good. GM also made an intake with the runners parallel to each other that has a better shot at the port. That one was used in the Grand Sport Corvettes in both weber carb side draft, and injection versions.
    David
  9. David Pozzi
    David Pozzi
    My intake has the same casting number.
  10. 392sniffin6
    392sniffin6
    Thanks Dave ! You definitely know your stuff!
  11. 392sniffin6
    392sniffin6
    I wonder what car this was built for? Anyone have any pictures of Stock Block Indy engines from the early to mid 60's ?
  12. 333 Half Evil
    333 Half Evil
    Here are a couple pics of the weber version. I believe the one with injection was designed for turbo applications, as someone already stated. I'm trying to find pics, but the one I saw was on a cosworth indy motor. I'll post them if I can find them.
  13. 56oldsDarrin
    56oldsDarrin
    I dont even like SBC's, but that thing is WICKED!
  14. 392sniffin6
    392sniffin6
    I have only been able to find pictures of the Cosworth Indy Cars as well ,those are some nice manifolds you posted pictures of I think they are Moon's. This one is a Factory GM manifold. Thanks again for looking for pictures!
  15. 392sniffin6
    392sniffin6
    I am with you on that one, I am not really a SBC guy either but this one makes me drool !!!
  16. Mr. Zora Duntov ,rip, would have the answer. I can't help much on the identification but would like to comment on its uniqueness , it would certainly be cool in a Chevy museum on a replica engine it was used on. Perhaps someone has a picture to post as the thread moves on its course. Hope to see some more history on it. I wonder what it is valued at?
  17. David Pozzi
    David Pozzi
    Here is the Corvette Grand Sport intake. I like this one much better. These ran Webers, 58mm side drafts, or fuel injection bodies were added like this one. The runners are much better, more equal length, less curves. This intake looks a lot like the base for the late 80's Tuned Port Injection. The throttle bodies appear to be Hilborn, but they don't say hilborn, just some numbers.
    David
  18. Russco
    Russco
    from Central IL
    Not to hijack or anything But, David Pozzi Is a member now! Glad to have you with us
    you should do an introduction for the guys that may not know who you are
  19. 333 Half Evil
    333 Half Evil
    I did find some info that these started out when the CERV I and later CERV II cars were built. GM planed on using them in the GS corvettes. Have not found pics of the injection one on an engine yet, but I'll keep looking through my stuff.....
    Some of the articles I've found, these things were also used on some formula 1 engines, even some other road race cars that had small cubic inch engine rules. They wanted to go with the cross ram or "lay down" desing so they could be kept under the body and not stick up like the typical hilborn/kinsler injections did. There were a couple of 4liter and smaller V8's that chevrolet built for testing in the CERV that made HUGE hp numbers and spun some serious rpm's!!! Cool stuff, kind of fun reading about it again.
  20. David Pozzi
    David Pozzi
    I saw the CERV at Monterey Historics a few years ago. I think it's owned by Mid-America now. Also I think they purchased the rear engined GM prototype (corvette?) or whatever it was. Smokey says in his book he cut it into 4 pieces but someone put it back together.
    Mike,
    Where do I do the intro? Here or is there a section for that?
    I'll look around.
    David
  21. David Pozzi
    David Pozzi
  22. David Pozzi
    David Pozzi
  23. 392sniffin6
    392sniffin6
    Hey everyone thanks for all the info , I am fairly new to the Hamb but I have always been impressed with how helpful and knowledgeable this community is.
    I have had some new updates as to the more possible history of this manifold. I spoke with a some one who today who said this manifold is the earlier version of the ones found on the Grand Sports. He mentioned these were the first prototypes and that they experimented with fuel injection on a few motors one of which was a Hemi Headed twin spark plugged 377ci Aluminum Chevy. The motor was never used but it did run. I am a Hemi guy so this was great news to me !
    I also had time this morning to put together a mock up of what this engine might have looked like and I will post pictures of it tomorrow.
    Thanks again for all your help and big thank you to David for becoming a member to help out a fellow enthusiast.
  24. 392sniffin6
    392sniffin6
    Well I don't have a lot of Chevy stuff but I was able to put this mock up engine together using some stuff I had lying around. Its a 1964 327 and some late model alum heads. The original block would have been made of Aluminum so I painted this one as such.
    kidcampbell71 likes this.
  25. Velocetwo
    Velocetwo
    There always seems to be confusion on the SBC Crossram set up. This setup was designed by Giotto Bizzarrini while working for the Iso Rivolta company. He is the same man who designed the Ferrari GTO and the Lamborghini V12 engine, so it makes sense that sense that he designed the beautiful Crossram set up earlycrossram.jpg . The first manifolds were hand welded and incorporated a gear drive mechanism to control the four side draft Weber carbs. A lot of linkage systems have been tried over the years with cross ram set-ups, but Bizzarrini's is still by far the best. It allows you to individually tune each carb without affecting the linkage connecting the other carbs.
  26. Velocetwo
    Velocetwo
    castcrossram.jpg As the design evolved it was cast in magnesium and aluminum at the Campagnolo factory in Italy, Bizzarrini also designed a Magnesium oil pan, brake calipers and large 10" wide rims.
  27. Velocetwo
    Velocetwo
  28. Velocetwo
    Velocetwo
    Bizzarrini started his own company after leaving Iso Rivolta and used the crossram set up on his street and race cars
    12523998_999508866786348_188192981188832875_n.jpg 12523998_999508866786348_188192981188832875_n.jpg 7087501603_a739e69f83_k.jpg 180540_Engine_Web.jpg
  29. Velocetwo
    Velocetwo
  30. Velocetwo
    Velocetwo
    Bizzarrini 1966 LeMans style P538 and a Bizzarrini hillclimb car both use the crossram setup
    DSC_8028.jpg b car
