History Need help to identify if car is a 35 or 36
Discussion in 'The Hokey Ass Message Board' started by Petemachinist, Aug 7, 2016.
  1. Petemachinist
    Petemachinist
    Hi everyone
    Looking for some help
    Having trouble trying to identify if this is a 35 or 36 and what the difference is
    Appreciate the help from you gurus
    Thanks
    Pete
  2. tjelwood
    tjelwood
    from oklahoma
    That's a 35 the front sheet metal on the two cars are different
  3. flamedabone
    flamedabone
    It is a '35, but it doesn't matter either way, grab it. And grab that Merc. And, you better grab all that other stuff while you are at it.
    -Abone.
  4. Texas Webb
    Texas Webb
  5. rusty rocket
    rusty rocket
    35 front fenders swoop into the running boards(like 33/34) and 36 come down and then turn and go to the running board.
    Petemachinist likes this.
  6. TagMan
    TagMan
    Taillight stand is '35. The stands on the '36 are more "swoopy".
  7. verde742
    verde742
    and 36 front fenders are two pc. and have horn GRILLES..
    Petemachinist and lothiandon1940 like this.
  8. tub1
    tub1
    from tasmania
    definatally 35 has 35 rear fenders as well as 35 fronts
  9. lewk
    lewk
    from Mt
    Early '35 at that. The cowl sides are smooth, no X stamping, and there is not spot for the rubber hood bumpers '36s had.
  10. verde742
    verde742
    look again the "x" is there.:rolleyes:
    standard 1 wiper, standard steering wheel, note headlite mounts...
    tap the picture it will grow.....
  11. millersgarage
    millersgarage
    I know someone who needs those taillight stands.
  12. Doesn't look rusty enough to be local produce.
  13. verde742
    verde742
    can you show pictures of that model T tudor in back ground? :oops: availability?
  14. Dooley
    Dooley
    from Buffalo NY
    Some late 35s have the x on the firewall... Everything else is 35
    Sent from my XT1254 using The H.A.M.B. mobile app
  15. '35 headlight stands are a separate piece that goes between the fender and the headlight bucket, while the '36 headlight stands are stamped as an integral part of the fender, so '36 headlights are not as high up off the fender as '35. The '35 headlight buckets are the same as '38-'39 truck. The bucket itself is the same for '36 car, but the mounting stud is shorter. '35-'39 truck uses the same lens and ring as '35 car. The '36 lenses are more convex or "bug eyed" and take a different ring. I have '36 bug eyes on my '38 pickup, best thing you can do for the front end appearance of '38-39 Ford trucks.
  16. lewk
    lewk
    from Mt
    I see a ding and a crease, no X.:rolleyes: In the 3rd picture, I think what you're reading as the line going forward and down is either a shadow or weathering. The ding that reads as the top of the line going forward and up is too far back. It should be right at the corner where the firewall bends down. You can also see the smooth panels in the first two pics. It's late, if my description doesn't make sense I can take some pics tomorrow. I've got 5 35-36 cowls sitting around right now.
    The car is also a deluxe, its got dual taillights and a waterfall.
    Definitely worth grabbing.
  17. verde742
    verde742
    Probably Ontario, Oregon.
    probably Ontario, Oregon..
  18. Petemachinist
    Petemachinist
    Hey gang,
    Sorry I haven't checked in to see this post. Thanks for all the reply's I now know for sure what it is. I will hopefully be picking it up around the middle of September and bringing it home. I will do a thread once I have it and the donor car in my possession.
    Perhaps some of you guys that really know these cars can tell me what is missing off the front end as in panels or frames for the rad. Obviously I see the hood and grille are missing but not sure if there is a rad cradle or other mounts or parts missing.
    If anyone could add some pics that would be great
    Thanks in advance
    Pete
  19. Petemachinist
    Petemachinist
    Also unable to find a vin number on it but there was a 6W115 clearly stamped on the firewall.
    Any ideas?
  20. Petemachinist
    Petemachinist
    No it definately is not lol
  21. lewk
    lewk
    from Mt
    VIN should be on the top of left frame rail, near the steering box mount. There is a small filler panel that lives ahead of the front cross member between the frame rails missing. The grille is missing, as is the louvered panel that fits between its lower mounts. The radiator mounts on top of triangular gussets ahead of the cross member, one on each side, attached to the frame rails. Yours are *probably* there. The top of the radiator has rods that run to the firewall. Your hood is missing (obviously). Sorry, I'm at work, no pictures.
  22. Petemachinist
    Petemachinist
    Here is a pic that was sent to me of the front that is there hopefully that tells more of a story lewk and everyone else.
    Thanks
  23. Petemachinist
    Petemachinist
    appreciate all input and any leads as where to find missing pieces
  24. lewk
    lewk
    from Mt
    Sorry for the ****py note quality.
  25. verde742
    verde742
    Wash. State made dealers install p***. tailite till 1941, when it became norm from factory..
    think Oregon did also.
  26. Atwater Mike
    Atwater Mike
    Wow, Verde...How'd the dealers know back then it would become norm in '41? :D:p
  27. verde742
    verde742
    I guess Dealers JUST Know stuff..:rolleyes:
    Hnstray and Atwater Mike like this.
  28. VIN should be on top of left frame rail near steering, it should also be in two other places that are not visible without removing the body on top of the left frame rail under the body. See: http://www.vanpeltsales.com/FH_web/flathead_serialnumbers.htm
    Charlie Stephens
  29. Dooley
    Dooley
    from Buffalo NY
    i have a stock radiator that was converted to pressurized and had a trans cooler added back in 1986 if you need one
  30. Petemachinist
    Petemachinist
    Thanks I appreciate the info
    So are the rad mounts there or missing I am not quite sure by your post
    Everything else was clear
