Hot Rods Need Help with 34 Ford Rear Spring Hangers
Discussion in 'The Hokey Ass Message Board' started by Yamanine, Mar 11, 2026 at 12:21 PM.
  1. Yamanine
    Yamanine
    I have on original 34 ford sedan ch***is. I want to take the banjo rear out and swap an 8" Ford in. The original spring and crossmember are in excellent shape and I would like to use it. Can I simply use the normal rear spring perches and just **** them at the appropriate angle to match the curved spring and weld them on the axle? I haven't been able to locate a weld on perch kit that is designed for a curved rear spring. It's either that or I'm going cut it out and go with coilovers.
  2. alchemy
    alchemy
    If they are the correct length, sure you can. Gotta be somebody that makes them. Even if you need to cut them yourself, it would be a lot less work than replacing the whole crossmember.
  3. Yamanine
    Yamanine
    That's what I was thinking. It would be a real time saver and cheaper. I'm just surprised no one makes them. Everything I've found says "Will Not Work With Original Spring and Crossmember"
  4. Tim
    Tim
    from KCMO
    So 8” fords came with two different tube diameters. If you have the smaller and you ordered spring behind hangers from Pete and Jakes for the bigger size you could easily tilt them to the correct angle and weld them up.
  5. Yamanine
    Yamanine
    Good Point. I didn't think about that.
  6. alchemy
    alchemy
    Pete & Jake’s part number 4019 or 4019-A.
    Pete Eastwood likes this.
  7. Yamanine
    Yamanine
    Dang Alchemy, you found it! Thanks!
