Technical Need help with 52 Ford skirts
Discussion in 'Traditional Customs' started by Cotterkey, Sep 20, 2016.
  1. Cotterkey
    Cotterkey
    from SD
    I bought these skirts off eBay, I have seen several identical sets all listed for 52 /54 ford all models. The last set set I say were described as flat overlay skirts. In my opinion the fit is terrible , Can anyone give me some insight on these skirts? They are NOS fox craft. Thanks In advance.
  2. loveoftiki
    loveoftiki
    from Livonia,Mi
    Yep.....they will need some help to fit right and work right. Just went thru this with friends 54 ford..after tweaking and "working" on them we go them to fit ok....of course now he doesn't run them
  3. Cotterkey
    Cotterkey
    from SD
    That huge gap in the front that doesn't follow the body lines is what really gets me. Did you do anything about that on your friends 54? Thanks
  4. Squablow
    Squablow
    I don't think those are the right skirts, I had a set for my '53 and they had an indent in the front that followed the fender blisters properly. Not to say you couldn't reshape these to make them work but they aren't made to fit that car.
    I have a couple sets that look near identical to yours and they were a generic aftermarket overlay skirt, made to fit lots of different cars as long as they had relatively flat quarters and didn't have stone guards. That's what is on my '55 Packard, and I did have to bend them up a bit to make them fit but they work.
  5. 54vicky
    54vicky
    as squablow said not for 52-54 ford.typical ebay listing so and so said they fit on his or her witchamacallit so must be gospel.they are not even close to being right.
  6. Chris
    Chris
    Yep, not the right skirts. The ones you want will be easy to spot...they have the crease in the front that matches the body. Here's a pair of foxcrafts I just painted on my 53
    cactus1 likes this.
  7. There is also in inset style of skirt available for it.
  8. 302GMC
    302GMC
    from Idaho
    Don't use skirts on something lower in front than in back.
    Atwater Mike likes this.
  9. Chris
    Chris
    Exactly. Those tips I got from you worked perfect by the way!
  10. Atwater Mike
    Atwater Mike
    ...and use flat exhaust tips that look like they go with the skirts and lower rear!!! (Like Chris's above)
  11. Cotterkey
    Cotterkey
    from SD
    Thanks for all your replies! I just thought maybe I was missing something as so many different people were selling these skirts for my application. It totally makes sense that these are a universal style skirt.
    I guess I will hang them on the wall for now and wait for a decent deal on the skirts I need. Hopefully my mistake will save someone else some cash. I love that Sunliner by the way!
  12. 54vicky
    54vicky
    I should have let you know for future reference on parts questions for your car.check out Jeffs 54-59 ford social group on the HAMB also ford barn and another is flatheads forever.I realize yours is a 53 but a few things from 54 will work
  13. Cotterkey
    Cotterkey
    from SD
    Thanks, I will check those out. I am always looking for ideas and , I have plans to drop the rear another inch or 2 this winter and put dual exhaust on it , I have a Dougl*** left side manifold on it way from eBay as we speak. I am also going to run spider caps in the front if I cant find some decent 16" hubcaps. Right now I am running Aerostar springs in the front with 2 inch blocks in the rear thanks to reading posts on here. Thanks again.
  14. missysdad1
    missysdad1
    I have a couple of sets of the right skirts that I will sell. PM me if you are interested.
  15. Not the Foxcrafts for your vehicle.
    Foxcrafts are "overlay", but those which you have there are for a ? ? ?
  16. "I am also going to run spider caps in the front if I cant find some decent 16" hubcaps."
    Be careful, the factory wheels for the 1952 Ford are 15".......with 6.70 x 15 tire.
  17. Cotterkey
    Cotterkey
    from SD
    My buddy thought that 16" wheels were not factory equipment for the car also, but I just purchased another 1952 Mainline one owner car at a farm auction a couple weeks ago and that one had 16" wheels also they both came with the small ford hubcaps but I took them off my driver. I wish they were 15" It would make life much easier to find some decent hubcaps .
    I did install 3" blocks in the rear today in place of the 2" . I must say, much better stance! Thanks
  18. Ford info book for 1952 shows 15" wheels as factory equipment.
    Don't know, though, the last year for Ford with standard 16" wheels.
    I stand corrected, have found another source stating the '52 has 6 x 16 wheels.
  19. Cotterkey
    Cotterkey
    from SD
    Thanks for the info! Thats exactly what both cars have on them is the 6x16 wheels, I had to work the day of the farm auction and had a buddy go look and bid for me on the second mainline , It was in very rough shape as far as rust , but one of the first questions I asked him on the phone was what size were the wheels . If it would have had 15" wheels I would have been willing to bid higher. Luckily I think we were only bidding against s****pers and I got the car for a song.
  20. Chris
    Chris
    16's were an option through 1954 I believe
  21. The 16s might have been an option for people who lived in the country and drove on rough
    and rutted roads...... Otherwise, I would think 15s were used starting in 1949 probably. On
    the old Plymouths, they switched from 16 to 15 in mid 1947 as I recall.
  22. Cotterkey
    Cotterkey
    from SD
    Both cars came from South West Minnesota , We took 4 1/2 miles of gravel to get to farm auction car , So that would make sense to get the most clearance for the snow and the rough roads. My 48 Desoto had 15" wheels so that would probably be correct also.
  23. jerdan
    jerdan
    I have a set of those on my 53 vicky. They follow the the body line and look good. See avatar.
