need help with 55 pont trim
Discussion in 'The Hokey Ass Message Board' started by SKULLZ, Aug 5, 2009.
  1. SKULLZ
    SKULLZ
    Got the 55 pontiac painted and they didnt put the trim back on as they were scared. I have alot of the original clips but cant find any more. Does anyone make a plastic or nylon clip that I can put my trim back on with? Is there a secret different way to put trim back on?
    Skullz
  2. SKULLZ
    SKULLZ
    Is there anyone with an answer?
    Skullz
  3. 55chieftan
    55chieftan
    from Maryland
    I would imagine it would be the same type of clips that the chevy's use for their trim. I'd think they'd make them but I'm not sure.
  4. 55chieftan
    55chieftan
    from Maryland
  5. SKULLZ
    SKULLZ
    I'll look into that thanks.
    Skullz
  6. AeroMonte
    AeroMonte
    I used t-bolt clips on my 56 Pontiac. It's the type of clip that has a flat side with a spring that fits into your moulding and then a threaded bolt attached to the center that goes through your sheetmetal. You can then put a nut and washer on it to tighten it up. The clip company Wurth or Au-Ve-Co will have them. Check with some bodyshops as they will have contact info for the clip companys.
  7. cruzingratiot
    cruzingratiot
    from Detroit MI
    The Auveco Catalog details over 18,000 items in 700+ pages
    http://www.auveco.com/
    try here for all kinds of clips
    Paul
  8. chopolds
    chopolds
    from howell, nj
    1. Kustom Painters
    If you've got the StarChief trim that is real wide up at the top, clips are difficult. I wound up welding machine screws to plates, and pop riveting the plates to the spots that the original clips went to, did that on my car. Other than that, standard T clips work.
  9. missysdad1
    missysdad1
    If you find a source, please be sure to post both the source and the part number here on the HAMB. I have a set of '55 Pontiac trim to go on my Vicky and will be needing clips. Thanks in advance...
