Need help with a Ford engine, coolant fan temperature switch
Discussion in 'The Hokey Ass Message Board' started by grobb284, Oct 23, 2009.
  1. grobb284
    grobb284
    from Ohio
    I'm installing a wiring harness on what I have been told is a Cleveland 351 in '29 short bed truck.
    I've only delt with small block Chevies in the past, where is the best place near the thermostat to put a temperature switch for the elecric fan for this engine? There is already a sender for the water temperature gauge next to the water outlet in the block.
    There are several ports near the water exit, some of which I assume are for the heater, which are not being used in this application, as well as another plug just below the gauge temperature sender.
    If you have a photo, that would help, as verbal descriptions alone are sometimes difficult to understand.
  2. studebaker1
    studebaker1
    from belvidere
    i put a bung hole into my radiator and treaded mine in there
  3. squirrel
    or put a fitting inline with the radiator hose.
    I'd think you'd want to measure the temp of the water in the radiator, not the engine...
  4. okiedokie
    okiedokie
    from Ok
    Some Ford thermostat housings come with a threaded bung.
  5. Judd
    Judd
    Mine is on the intake front driver side next to thermostat housing, works great.
  6. Judd
    Judd
    picture of mine.
