Need help with CHEAP but SAFE disk brake conversion.
Discussion in 'The Hokey Ass Message Board' started by 58Chev, Jul 18, 2006.
  1. 58Chev
    58Chev
    I'm looking at converting the front drums on my 58 Chev, Delray to disks. Hate to pay the prices that are being asked out there for repop stuff. Whether direct swap or 2"drop, either will do.
    Are there any GM vehicles out there that I can swap out the Spindles or better yet A arms and spindles?
    I have heard that downunder they use parts from a GM Holden (obviously a car not sold here, US/Canada)
    ThanX
    All suggestions would be greatly appreaciated.
    Chuck Deisel likes this.
  2. burger
    burger
    Copied from the HAMB a while ago:
  3. squirrel
    the cheapest way seems to be to get the aftermarket brackets, and scrounge some calipers and rotors, and a dual m/c.
    Otherwise the closest swap I could think of would be the more expensive late 60s GM factory disc brake stuff, and it's not a direct swap.
    sometimes you just gotta go with the flow....
  4. Tubby
    Tubby
    I loaned this dude a '64 Pontiac spindle and he made a set of brackets for the 59-64 fullsize Pontiacs to convert to discs. Conversion used off the shelf parts. If he doesn't have your application yet he can fab the brackets.
    http://www.scarebird.com/6928.html
  5. Redneck Smooth
    Redneck Smooth
    from Cincinnati
    Anyone know if this stuff works on an Olds of the same year?
  6. 58Chev
    58Chev
    ThanX, but unfortunately he does not support the 58. Just got an email reply back from him.
    burger,
    Great list of parts but what do those parts attach to? Would I still have to buy an aftermarket caliper bracket?
  7. squirrel
    the last item in his list is an aftermarket caliper bracket....
  8. spanky
    spanky
    I bought a caliper bracket kit from Impala Bob's it comes
    with spacers and hardware for $129.00 . It uses monte carlo rotors and calipers which you can easily find @ parts stores. I'm running a 74 corvette m/c. Check out Impala Bob's .com. Good luck Spanky.
  9. 58Chev
    58Chev
    His reply to my email....
    Frank, we checked out a 58 and realised it is a lone year, our stuff does not fit, so we will need to make a setup for it. (if we decide to go ahead...)
  10. burger
    burger
    I've never done the swap myself. I just save a lot of info from the HAMB and that's part of what I've saved.
    Anyway, the last line of the quote says that you'll have to buy an aftermarket adapter. The original poster made it out to be a fairly common part and even lists two vendors.
    Hope this helps,
    Ed
  11. 58Chev
    58Chev
    Anybody know if these parts will fit on the full 2" drop spindles or do I have to buy the callipers brackets and attach to thye original spindles?
  12. squirrel
    which drop spindles are you talking about? many of the aftermarket drop spindles are made for disk brakes....no adapter needed.
  13. 58Chev
    58Chev
    If I decided to purchase drop spindles, say from LateGreatChevy... Can I then proceed to hunt parts from the list above?
    OR
    Do I have to purchase the brackets to be able to use the parts from the list above?
  14. 49ratfink
    49ratfink
    if you are buying dropped spindles the best thing to do would be to check with the manufacturer and see what calipers,rotors, and brackets they recommend
  15. squirrel
    yup, you'll probably need different rotors and calipers....there is better stuff out there now than what was used on the old adapter kits
  16. mazdaslam
    mazdaslam
    Forget the dropped spindles. Spend that money on caliper brackets and brake parts. One coil cut from the spring is about 2in of drop and works fine.
  17. Chuck Deisel
    Chuck Deisel
    I have a 58 Delray 4 door that I want to convert to power brakes,especially the front. Is there a easy/inexpensive way to do so that you've found?
  18. tfeverfred
    tfeverfred
    This thread is 7 years old, you may need to PM him.
