Projects Need help with identifying car
Discussion in 'The Hokey Ass Message Board' started by dhughens, May 5, 2015.
  1. dhughens
    dhughens
    Can someone identify this front suspension and body style . I am told it is 1917 Dodge according to the ***le of the car . However, I cannot find anything similar on the web to verify. Here is a picture of the car. It also doesn't seem to be a Dodge from what I can find on web images. The firewall vin matches the ***le so I'm not sure of anything at the moment. Thanks for any insights, dan...
  2. Rocky
    Rocky
    Classified Editor
    Body appears to be a 26-27 ford coupe with the top cut off. Front suspension is 40-47 ford. 39 and earlier didn't have a sway bar and 48 had tube shocks
  3. JimSibley
    JimSibley
    Rocky nailed it!
  4. Martin Harris
    Martin Harris
    Definitely a 26 or 27 T Coupe with the roof whacked off. Personally I like 'em "roof on", but it's certainly a little different.
  5. coupe33
    coupe33
    The body looks like 26/27 T with the bolt on roof seam removed . Coupsters look good and you don't have to worry about chopping too much and not being able to get in it! I looked at an old dodge roadster and other than the back of the seat where it rises it is very simular. It is pretty slick looking no matter what it is!
  6. Binger
    Binger
    from wyoming
    Those shocks are delco lovejoy that ran on a lot of different cars in the 30's. My '30 Chevy came with some stock and I set up a set to run on my '29 A coupe.
  7. timwhit
    timwhit
    The p***enger compartment looks real long for a T coupe. Judging by the door size and how small the quarter windows are on a T, I'm not sure. Opera coupe is what I see. We will figure it out!! Tim
  8. 3wLarry
    3wLarry
    from Owasso, Ok
    the term "you can't polish a turd, but you can roll it in glitter" comes to mind.
  9. da34guy
    da34guy
    Couldn't of said it better Larry.
  10. It is not a '17 Dodge it is a cut down sport coupe with a '37 up spring in front of the front axle setup.
    I hope if you bought it you don't get pulled over by a real police officer even Lou Rawls could see that it is not a '17 dodge.
  11. patmanta
    patmanta
    from Woburn, MA
    I need to see a better picture of the cowl.
    I have seen this car on the web before, did you just buy it?
    Welcome to the HAMB by the way, I see this is your first post.
    I actually own a 1917 Dodge Brothers. You can see what the original stuff looks like in this thread.
    http://www.jalopyjournal.com/forum/threads/drug-home-1917-dodge-brothers-touring.947165/
    From what I can make out, the guys above are partially correct. What I think you have there is the back end of a T coupe but the cowl does indeed look like a 1917 Dodge Brothers.
  12. patmanta
    patmanta
    from Woburn, MA
    The Yellow OP one, or my yard art?
  13. LOL certainly not your yard art. I really like the little racing wheels on the back, talk about a way to get rid of unsprung weight. :D
    A little off topic but is that an aluminum Curtis nose?
  14. Lou Rawls?!?!
    tb33anda3rd and volvobrynk like this.
  15. patmanta
    patmanta
    from Woburn, MA
    Nose is gl*** actually. Wheels are jankier than they look, they're just welded to a pipe to roll it around. They have since come apart so, yeah, there's that.
  16. Did I spell it wrong? I can never remember the other blind guys name.:oops:
    volvobrynk likes this.
  17. Andamo
    Andamo
    Lou Rawls wasn't blind, Stevie Wonder is.
  18. raidmagic
    raidmagic
    Is it really necessary to bash the guy's car? That doesn't seem very "community"
    patmanta likes this.
  19. LOL edit Ray Charles. DuhOh
    Stevie Wonder is the one who I can never remember. For some reason his name just gets lost in my head, and now evidently Ray Charles. :oops::p:D
  20. The37Kid
    The37Kid
    That body does look like it may be Dodge, Coupe back with a Roadster cowl. More photos would help ID it. Welcome to the HAMB! Bob
  21. patmanta
    patmanta
    from Woburn, MA
    If it's a Dodge coupe or roadster back, it's later than 17 probably. The 17's I've seen have that rounded box turtledeck look. But, take a look at the sweep up at the back of the cab, this is not present on later DB roadsters whose decks are just about level with the seat back. I'm leaning towards a cut down coupe of some sort for the rear, probably a notaford of about 1925ish vintage.
    17 Roadster:
  22. They were still using that same turtle deck in the late 20s that was why I said no on it.
    The turtle deck on the car mentioned looks pretty ford to me.
  23. patmanta
    patmanta
    from Woburn, MA
    It might be Ford rear quarters, but they'd have to be 26-27 coupe and stretched on the front to meet the doors.
  24. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    It's a Franken-roadster! Built from the parts of those that came before it, and ***embled with surgeon-like precision under the watchful eye of a mad builder.
  25. The37Kid
    The37Kid
    Stole this 1927 T Coupe photo from Django in the cl***ified section.Something is added to the sill on the yellow car, frame rail looks to have a cover over it too. Bob
  26. 3wLarry
    3wLarry
    from Owasso, Ok
    I most humbly apologize...I don't know WHAT came over me...I didn't know the Hamb is now a "community"
  27. dhughens
    dhughens
    1917 dodge interior.jpg View attachment 2902262
    Thanks for all the responses. Here are a couple of additional pics. I think Patmanta is on the money about the front of the cowl. Here is a pic I scavenged off the net with a pic of the rod. I believe the cowl is indeed 1917 Dodge
  28. dhughens
    dhughens
    Well, so much for that last reply, I'll try again. 1917 dodge interior.jpg hot rod interior.jpg
    I'm comfortable that the forward section is Dodge, I understand that the 17's did and did not have glove boxes but note the map light and speedo hole. I have taken pictures of the frame and will post later. I have identified the radiator shroud as 1923/24 Chevrolet. I think Rocky has nailed the rear of the body. What cons***utes what a car is? The frame, vin number, body?? With a Chevy nose, Dodge cowl, Ford suspension and rear section, Pontiac drivetrain, and a Dodge ***le matching the cowl serial number, I really have a mutt. I don't mind that at all but the whole car looks as if it was put together by a 17yr old without resources in the tradition of a real hot rod. There is a lot of "cobb job" workmanship and I'm not sure whether or not I want to redo the awful areas. I really like the authenticity of ***embly with little or nothing available. Example: the mounts for the engine and trans are 3/16 steel cut with torches and arc welded together. No cleanup or finesse. Most of you probable haven't seen that kind of work since the 60's. Functional but crude. hot rod needing rework (8).jpg hot rod needing rework (10).jpg
    I appreciate all the input, especially finding out about the front suspension. No offense taken about anything. All perspectives are welcome whether or not I agree. Thanks for taking your time to respond. dan...
  29. verde742
    verde742
    DHUGHENS :: You, my friend, are an awfully good Sport !!!!
  30. patmanta
    patmanta
    from Woburn, MA
    @dhughens I would drive it all summer first and make a list of things you want to change with that experience.
    Start work this Winter.
    The most recognizable feature of the car, for me, is the cowl, which is the ***le/reg for the car, so, that's what it is as far as I'm concerned. My cowl has a glove box too BTW.
    The first think on my knock list though would be anything that looked cobbled together as to be potentially unsafe. Those mounts look suspect.
