need help with ignition
Discussion in 'The Hokey Ass Message Board' started by ziggycali24, Jun 25, 2006.
  1. ziggycali24
    ziggycali24
    Thanks for reading this. I have a 1953 Chevy 210 with the 235 L6. I can not get spark to my plugs. I have spark at my points and it is a strong spark. The distributor cap is in good shape with a little bit of carbon burn. The problem is I can not get spark to the plugs. I bought new coil negitive coil wire is hooked to the srcew sticking out on the distributor. Where should I start to look for the problem. Thank you.
  2. Points gapped too far.
  3. topless54
    topless54
    I had a similar problem w/ my 12 volt distributor. My problem was the condensor. I tried everything else before I bought this 4 dollar part (I used to use HEI).
  4. gasheat
    gasheat
    from Dallas
    Did you install the rotor? Is your condensor good?
  5. theHIGHLANDER
    theHIGHLANDER
    Strong spark at the points is almost surely the condenser. They were designed to prevent that.
  6. Oldsmobucket
    Oldsmobucket
    had a similar problem with my olds when i reinstalled my dist. i changed points and condenser twice. finally found a break in a groundwir in the dist. made a new one hooked it up and she fired right up. just my .02 good luck
  7. ziggycali24
    ziggycali24
    I Put In New Condenser Now I Get No Spark At All. Have Not Checked Groundwire Yet. I Took My Plug Wire From The Distrbutor And Left The Coil Side Hooked Up And Sparked It At The Valve Cover Spark Was Really Weak Have New Battery In The Car. Any Ideas?
