Need help with Pontiac motor mounts
Discussion in 'The Hokey Ass Message Board' started by 331 ABOD, Oct 2, 2012.
  1. 331 ABOD
    331 ABOD
    from minnesota
    Putting a 67 pontiac 326 into model a frame, Th 350 and looking for info. as to who makes aftermarket motor mounts for this swap. Saw an old post here, someone was into Pontiacs also....Hellonwheels ????? Would appreciate any and all assistance Thanks
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    Block up the engine and transmission between the frame rails and figure it out.
  3. 55chieftain
    55chieftain
    There is a later style side mount Hurst mount, but it's not worth the time or money to try and find one. The early style bolts to the cover, but I wouldn't do it with an aluminum cover. Set it in place and build side mounts...
    Or maybe try a universal tubular crossmember if you have room where it would come up to the frame..
  4. Snot Rocket
    Snot Rocket
    IIRC, Pontiac V8 and SBC motor mounts are the same. Or at least they are the same location, relative to the front and rear parts of the engine. TH350s all have the same rear mount, only the engine bolt patterns differ.
  5. treb11
    treb11
    the bolt patterns on the engine are WAY different. the locations of the factory style frame mounts might be the same, but the motor piece is different.
