Technical NEED HELP WITH QC REAR END RATIOS FOR FLATHEAD W/ T5 TRANSMISSION
Discussion in 'Traditional Hot Rods' started by roll of the dices, Feb 25, 2021.
  1. ems customer service
    YOUR TRYING TO HARD ON YOUR MATH, 1st get the car done, make it drivable, rear tire size makes a difference also, you can play around with some different sized used tires and old steel rims to help you get a better idea, your never going to know how the engine runs till your done, remember ford and gm have test tracks for a reason. al***ude makes a difference, and how hilly your local area is.
    loudbang and firstinsteele like this.
  2. Deuce Lover
    Deuce Lover
    Like Krylon said.3.78. I had a 36 coupe with a 59 A flatty (4" crank ,Potvin 3/8 super cam,2 -97's)T5 and 9" rear (6.50X16's). I tried 3.90's and was to low.Then 3.78 which was perfect.The T5 had a .076 5th gear.I lived in CA high desert then and it would pull 4K mountain p***es with ease.
