I have a 36 and mine doesn't have that middle bow between the rear and front. unscrew the windshield and pull the levers down below the wood bow and she should go.
Yeah I can only get to this point what do I do next ??? Levers been pulled the top iron bar is in the way ? Won’t let it do the accordion
it does take a little wiggling as it collapses you move the top material and push slightly down as you go
"'39 convertible top lowering instruction #3; Unsnap fasteners around back curtain (Window) and drop into package tray. This is after #1, lowering the door gl*** and #2, unsnapping the 4 fasteners located above the door gl***. " A insert from a Early Ford V8 forum post. Do you have extra fasteners still attached along your rails? Don't know how similar to yours it is, but the last around the last 3 minutes of the video shows them putting the top down.
