Need help with year and model
Discussion in 'The Antiquated' started by el marage, May 20, 2021.
  1. el marage
    el marage
    20210401_023116.jpg 20210520_174805.jpg 20210411_184947.jpg Need help with year and model. Hope this is the right category
    Thanks
  2. el marage
    el marage
  3. el marage
    el marage
    20210323_183131.jpg 20210331_190622.jpg .
    Deuces likes this.
  4. squirrel
    57-59 GMC ch***is, going by the few clues I can see, such as the front bumper, dashboard, and steering wheel. I can't read the tag, getting a clear, large picture of that would be a help. Many of the old Step vans had bodies made by independent companies, and this looks like it's probably one of those.
    Deuces, Tim and pitman like this.
  5. el marage
    el marage
    Deuces, mgtstumpy and squirrel like this.
  6. oldiron 440
    oldiron 440
    The front reminds me of the bookmobile that came to my grade school in the 60s.
    Deuces, hotrodjack33 and Joe Travers like this.
  7. squirrel
    P2503 is the model number, it's 137" wheelbase. I don't know if the year is in the serial number somewhere...GMC did not make it easy to figure them out. They used letter codes for the year, but I can't tell which letter means the year. N is 1960, but the rest of the truck looks like it cannot be newer than 59, perhaps they carried over the step van ch***is for a little while. Strange.
    Deuces and Tim like this.
  8. F-ONE
    F-ONE
    from Alabama
    It looks a lot like a "Boyertown" body step van, but many companies were similar. The big tag above the one pictured should tell.
    squirrel and tdog like this.
  9. hotrodjack33
    hotrodjack33
    It's sitting next to a F*N Dodge, if that helps;)
  10. el marage
    el marage
    Here's a pic of the above tag
    Will get a better one tomorrow
  11. squirrel
    whatever the word is before "URBAN DELIVERY" on that tag, is the name of the company that made the body.
    I can't puzzle it out, but I expect you could if you took a real close look, and moved the plastic out of the way a bit also
  12. F-ONE
    F-ONE
    from Alabama
    Likely this thread will get moved to the "Antiquated" part of the HAMB where we discuss such things.
    It's not a Boyertown. Boyertown out of Boyertown PA tended to use Ford products. I have seen one of these before, not exactly like yours....not with the built up roof.
    This company used primarily GM ch***iss'.
    These are very interesting. Like Boyertown these vehicles kept their "late 40s-Early 50s styling well into the 1960s. If you notice this one has an "Advanced Design" type grille. The Boyertowns Kept the Ford F-1/F8 type grille well into the 1960s as well.
    These are actually very useful. They can do things nothing else can, many things. They actually surprisingly maneuverable.
    One problem though will be wheels as many had "widow maker" type wheels. More modern type 'Bud" wheels may be available. The wheel thing takes some research because not all multi piece wheels are "widow makers".
    You need to clean up those tags carefully with a wire wheel. They are not readable with all the paint on them.
  13. squirrel
  14. I think Jim got it again. Looks like from what I can make out *ontpe* on the tag 20210521_080701.jpg 20210521_080720.jpg
  15. quickfarms
    quickfarms
    I would not clean the tags with a wire wheel.
    I would use solvent, since they painted over the tags it was probably not painted professionally and the paint may just dissolve
    squirrel likes this.
  16. el marage
    el marage
    Tim likes this.
  17. el marage
    el marage
  18. el marage
    el marage
    What year do you think the steering wheel and cap are from
  19. squirrel
    The steering wheel was used on Chevy trucks from 57-59, I ***ume it was also on GMC s the same years. The dash is 55-59 GMC, as far as I can tell.
    Tim likes this.
  20. el marage
    el marage
  21. el marage
    el marage
  22. el marage
    el marage
  23. el marage
    el marage
  24. verde742
    verde742
    I would ask the guy who has the ***le.
