Technical need help
Discussion in 'The Hokey Ass Message Board' started by s19243h, Feb 22, 2016.
  1. s19243h
    s19243h
    from pottstown
    i have a 69 350 chevy that is in a camaro was doing a intake swap and found it was not a roller cam ,,as i was told it would be so i decided to pull a head because i was told it had 12:1 pistons also. i dont think these are 12:1 ,can some one identify this piston and maybe what the compression ratio is with 64cc brodix trac one heads 12744565_1151055464955902_8064608814212398565_n.jpg
  2. aaggie
    aaggie
    Looks like it might be close on the compression ratio. Years ago they would be called pop up pistons.
    It also looks like you twisted off a head stud. On Chevy blocks the bolts go into water so you need to seal the threads and don't screw in the studs until the threads bottom. Screw them in until they stop then back off one turn.
  3. squirrel
  4. s19243h
    s19243h
    from pottstown
    wich stud i didnt notice and do you know a p[art # on the piston
  5. s19243h
    s19243h
    from pottstown
    thank god its the dowel he sees shweeeeeew
  6. Dan Timberlake
    Dan Timberlake
    Busted Stud 5 at 2:00 o'clock. Head gasket stain suggests it may have been running (and leaking) that way.
    Rotate a piston to TDC and take a picture of the piston dome side view.
    Real way to tell is to CC the piston dome. It can be done with the pistons in the block, similar to as shown here -
    http://roskoracing.com/TechBlog/?p=115
  7. dirt t
    dirt t
    Great info thanks dan
  8. s19243h
    s19243h
    from pottstown
    ok i will check the stud and get a side pic at TDC thanks for your help
  9. s19243h
    s19243h
    from pottstown
    awsome post
  10. s19243h
    s19243h
    from pottstown
    OK i measured the piston at tdc and how much the dome sticks out then measured the dome level with the cylinder
  11. s19243h
    s19243h
    from pottstown
    its on the 8 or 3mm
  12. 34toddster
    34toddster
    from Missouri
    I vote for 11 to 1 CR
  13. Jalopy Joker
    Jalopy Joker
    now yank that motor out of the Camaro and put it in a '65 or older ride.
