Hot Rods Need help
Discussion in 'The Hokey Ass Message Board' started by 52lomofo, May 6, 2017.
  1. 52lomofo
    52lomofo
    Just wondering did winnebagos from the mid 70's have tilt column from Chevy found one the other day looks like the ones from the vans tilt with key on dash
  2. BJR
    BJR
    If it's a Chev ch***is it probably is a Chev tilt column.
  3. Hot Rod Grampa
    Hot Rod Grampa
    Size matters. Our motor home has a ford column but ch***is is an Oshkosh. A smaller unit may have the original sheet metal as in a one ton. May need to research vin#.
