Need help
Discussion in 'The Hokey Ass Message Board' started by 51flathead, Aug 17, 2009.
  1. 51flathead
    51flathead
    how do the back drums come off on a 51 chrysler windsor deluxe?
  2. alicia-dusty
    alicia-dusty
    Hi, those things can be a real pain, I had one in 1965. I remember reading in a manual that you can back off the big nut in the center "A LITTLE". And drive it a short ways, loading the rims both ways. Going around corners left & right to loosen the drums. Or a three legged puller.
  3. JohnEvans
    JohnEvans
    from Phoenix AZ
    Yep: Loosen the big nut in the center a couple of truns max. Then use a 3 legged puller the lug bolts hold to the drum/hub. tighten up TIGHT ,smack the puller center bolt firmly with a BFH.
