need help
Discussion in 'The Hokey Ass Message Board' started by SAM, Jan 30, 2006.
  1. SAM
    SAM
    I have a 1950 buick fastback. have the straight 8 rebuilt same trans.auto.. the door handles are shaved,french headlights,65 mustang gas tank in trunk. white walls with 57 cadillac hub caps.the inside has been work on.the inside has been worked on.they cut the springs 4 in the front and 5 in the rear dont like the ride.need help here to change this set up and up date the brakes. also have a two duce set up need help here to.any help i can use. thank you
    outsider392@sbcglobal.net
  2. rsg2506
    rsg2506
    Could you elaborate in full sentences perhaps? You are kind of vague on what problems you are having? Is the ride too harsh? Too low? A picture might help too.
  3. SAM
    SAM
    I like to know what front clip would work ? And need to know more on the two duce setup ,headers or stock.Then the rear end is the 4 link with air bags the way to go.
    thank you
    steve
