Technical Need info about Buick torqetube different lenght
Discussion in 'The Hokey Ass Message Board' started by Orn, Jul 1, 2016.
  1. Orn
    Orn
    A friend of mine with a 1948 Buick Special 248 straight eight and 3-speed trans want to change to a Dynaflow. Whats the different in length vs a manual 3-speed? I know its longer but how much? To get this to work he needs a shorter torqutube and the question is did a torquetube from a Dynaflow equipped 1950 Special fit in his 48?
  2. Jalopy Joker
    Jalopy Joker
  3. Bearing Burner
    Bearing Burner
    from W. MA
    The problem is getting the driveshaft off the rear end. If there is that much difference then change the whole ***embly. Buick shop manual does not recommend taking driveshaft off pinion.
  4. Orn
    Orn
    I change the the third member of my previous 48 without problems. The propeller shaft is connected to the pinion through a splined joint and a pin. But the question remains, will a torquetube from a -50 with Dynaflow fit right in to the -48?
  5. Gizzy
    Gizzy
    from N.W,Ohio
    My brother-in-law is needing a set of gears like described here,does anyone have a set to fit a 48' Buick?
