need input
Discussion in 'The Hokey Ass Message Board' started by BMR, Mar 19, 2009.
  1. BMR
    BMR
    from ill.
    I want to run a motorcycle style carb on my 2.3 ford.
    what would be a good starting place for carb size?
    besides spending a thousand dollars on one already built.
  2. harpboys4
    harpboys4
    from So Cal
    The problem will be size even the monster motors are not 2.3.That is why the inline four bikes have multiple carbs.Maybe a Dellortro or Mikuni might give you the look and be big enough.
  3. BISHOP
    BISHOP
    Trust me on this, car parts are for cars, bike parts belong on bikes. There is a reason they are different. Ive been through it, and the price for (the look) is worth it.
  4. weldtoride
    weldtoride
    By "motorcycle style" do you mean side-draft carbs? Weber side-drafts would be my suggestion. As stated above, most actual motorcycle carbs will be too small.
  5. maybe dual FI units off a newer H-D??:p
  6. RichFox
    RichFox
    You mean something like this? No, can't do it. It won't work. Everybody knows that.
      62.4 KB
  7. BMR
    BMR
    from ill.
    esslinger engineering has a setup that uses mikunis but its a thousand dollars. surely you can do something?
